this is swiftech solution.
with that solution dpf don't regen but you have that 3 fault code
possible solution is to remove dtc in swiftec file
We have a problem removing dpf opel corsa 2008 year 1.7DTR denso 92kw,
Need 100 % worked solution for this car. Don't need for free i will pay .
Attaching two files one orginal and modify by chiptuners.
With modify file car have 3 faults codes dif pressure hose line,temp sensor 1 temp sensor 2 plausibility. after 10km engine corsa d 898000 8207 mb275800-4677 98000820 CQ 17cdti dpf OFF.rarcorsa d 898000 8207 mb275800-4677 98000820 CQ 17cdti.rarlight on.
Ecu tuning, DPF, EGR and FLAP remove
never seen good solution for denso ecus
solved thanks for replays
