Results 1 to 8 of 8
Thread: Open aaf
    Top Poster + roblfcx5's Avatar
    Nov 2012
    2 dogs fightin. YNWA
    Default Open aaf
    I'm running open aaf and when I'm setting a timer to record it green screens saying error and shuts down on me
    Any help on this to stop it from happening
    Maybe remove some unused plugins, would solve the issue ?
    digicon's Avatar
    Try a different image if that cures it then problem solved if it does not then its a possible problem with the Clone 800se or even the Hard drive itself
    Nov 2012
    I will do a reflash, I'm just figuring out wich image would be best to use
    Openpli or newnigma seem to be the most rated, but for some reason
    I'm putting IP address into browser
    And All I keep getting is dreambox web control centre, tried diff browsers same thing.
    digicon's Avatar
    Boot the box from cold and hold in the mini-flashup button on the rear of the unit until you get the IP address on the small LCD display
    Nov 2012
    Yes I'm doing this m8 holding mini flash until
    **stop** appears then IP address appears, I then open browser
    Add the IP
    And it just comes up same
    Dreambox webcontrol
    digicon's Avatar
    Clear all that Crap off the Laptop then LOL
    You can flash it via the Mini USB cable as well
    Nov 2012
    Haha yea I will clean more of, but what I have removed made lappy a lot Quicker
    I will remove all iTunes stuff as its not needed & it takes up a lot of memory, but I still dnt think its gonna wrk
    What usb cable would I need ?
    digicon's Avatar
    USB to Mini USB
