Bump
Come on people, I know you guys can help me here
Cheers
Hi there
i manage to identify the ecu with an error but still picks up the hw and sw numbers. when i press read i get an error, is it because i need to pull out a certain fuse or fuses?
if so which ones? and where from ? cheers
The car has had an engine replacement with a different engine code, however i can run a diagnostics fine on it with vcds via obd.
Cheers
Bump
Cheers
Try without fuse 11.
There is a message in the software!
Regards!
motorsportsz (29th May, 2013)
my friend made same car and read via obd use MPPS all good!
after he take FGTECH2 clone china and car get error in eeprom and write in DTC tuning protection visit garage AUDI
Best regards.
Babos.
I also had issues with Fgtech china and Fgtech mini euro on me7.5 ecu's.
A lot of tools don't like ME7.5, even some original tools, like Genuine Magpro2 for example I have problems with these, Kess V2 clone failed, China G2 failed, From my experience, I use MPPS many times and works great
Yep funny ecu's. Some are done perfectly with mpps and some do only respond to old 1260.
Thanks everyone. I will try again with mpps v12 this time. Where is fuse11 located on these? Cheers
Just take it off and do it on bench with k-line it will work no probs (euro mini) i had the same but take 15 mins to remove ecu but hay no big deal....
Thanks kev
PM sent. I have never done k line on these ecu's. Can you send me instructions on how to?
Cheers
PM sent
Thanks kev
