Yeah they all work, and did a manual scan still just a black screen. Can I moanullay modify the PID and what should it be.
Cheers
Cheers
These settings are all that are needed, Check attachments
Try this see if it eliminates the problem
Thanks for all your help guys but still no joy, as I say SD Disney perfect![]()
Try one last thing, Either Reboot your box or pull the power supply out and try again, Might work
Where is the laterst SKY HD bouquet file? How do I download please?
HI,trying to load the lastest bouqeut and am getting this message??
** Sending file "/etc/enigma2/lamedb" **
Starting FTP transfer
Transfer aborted
Error sending file "lamedb" to the Dreambox.
Disconnecting.
Disconnected.
can anyone help pls
regards neil
Close down and try again, also make sure DBE is set to Settings type-4 (Tools>Toggle Between Version 2-4)
thank for quick reponse stg Dreambox response: Login successful.
** Getting directory list /etc/enigma2/* **
Transfer complete
Transfer aborted
Disconnecting.
Disconnected.
getting this now??
Try this guide :- http://www.digital-kaos.co.uk/forums...-guide-167275/
Make sure all settings are correct, For example the paths are correct for sending the files to your Enigma2 machine by following step 2 on the guide
many thanks stg will have a go cheers
Are you using the latest dbe if not then try that if you are try an older one
YES i on the new dbe but still showing ** Getting directory list /etc/enigma2/* **
Transfer complete
Transfer aborted
Disconnecting.
Disconnected.
Give me half an hour or so and I'll send you my e2 list to test with. Doubt if it will work though if the one from the sarge won't send.
many thanks mate ,it comes up on the screen software problem need to restart on a green screen as well when rebooting?
