Results 1 to 8 of 8
    Nov 2008
    Default sky f5 that i am stuck with
    hi there i have an f5 which is fully loaded but as i took it out the box for the 1st time and plugged it in i get nothing on the tv and on the disply keeps showing load and counting 1-100 then rebooting again -- is there any thing i can do to stop this and get it working again cheers
    digicon's Avatar
    Yes send it back to whom ever you purchased it from for either a refund or an exchange
    Oct 2011
    Check all leads are plugged in correctly then turn the plug off and back on, and if everything is plugged in and it does not work then send it back, faulty box or needs flashing with null cable but with it being brand new then a refund or replacement should be offered
    Nov 2008
    mate i have just discounted my sky signal to see if i could get anything and now its showing a menu so its now tellig me its the dish or wire not the box what do you think .......not getting pic on tv but says no signal and i cant even get fta channels
    Mar 2013
    the sat feed cable is causing box to short out check cable connection that all is ok, could be water leaked in outside
    DK Veteran mahrkpat's Avatar
    Jun 2012
    Quote Originally Posted by djcj View Post
    How was your sky and the F5 connected to the dish? Or do you mean something else?
    P&D's Avatar
    are you connecting both the cables or just one of them ???
    I had the same problem one cable would give me nothing
    disconnected it & plugged the other in & everything worked great.......not sure why
    DK Veteran jckw's Avatar
    Sep 2008
    check the resolution size on TV it may be not set right
    we are all learning each day
