Results 1 to 14 of 14
    Default 1998 MERCEDES SPRINTER T5 Transponder Logic
    Hello Mate;
    Kindly need help for T5 Transponder from the dump attached here which is from the TEMIC immobox Memory device Motorola MCU 68HC05 x 32 Mask OD62J of a 1998 Mercedes Sprinter i have here with all key lost problem.
    Best Regards
    Jun 2011
    near bigest capacitor
    Quote Originally Posted by ngakson2002 View Post
    Hello Mate;
    Best Regards
    id 12
    transponder type T5
    dump is seems ok.
    What kind of help you need?
    keygargoil's Avatar
    do you have any id12 ori chips i will add a key for you if you want what device are you using for your tp reading and writing
    keygargoil's Avatar
    Hello Mate;
    Best Regards
    write a t5 id 12
    key 1 66 0f DA A1 15 31 51 87
    key 2 66 0f 68 90 F0 EA F0 37
  5. The Following User Says Thank You to keygargoil For This Useful Post:
    ngakson2002 (1st June, 2013)
    Thanks Mate,
    I have programmed both keys LOGIC in Glass T5 transponder and no Joy.
    VAN start for 15 seconds and STOP.it is a 1999 MB SPRINTER
    Best regards
    Need transponder Logic from the dump in order to write it in T5
    Oct 2010
    When it starts it'd not a problem with immo system.
    keygargoil's Avatar
    the logic i gave you is the keys in your file write it to a t5
  10. #9
    keygargoil's Avatar
    that is tango logic il make 1 tomoz and read it on zed bull
  11. #10
    keygargoil's Avatar
    my zed bull is in the van do you haveone go into the extended functions calculate transponder from eeprom bytes and write these bytes in
    DA A1 15 31 51 then click ok this will write the bytes as zed bull reads it i have my tango gere but itr reads it as true bytes not random code
  12. #11
    Quote Originally Posted by keygargoil View Post
    Thanks Mate.
    Definetely Transponder Logic was the problem preventing the VAN from Starting.In fact the VAN started staright forward with the following Logic i obtained from SIERRA; to whom i once more say Thanks
    Logic is: C1 6F 15 A2 32 2A 86 9B
  13. #12
    keygargoil's Avatar
    thats correct there is 2 types of format the random code which zed bull uses and the true bytes that tango uses
  14. The Following User Says Thank You to keygargoil For This Useful Post:
    ngakson2002 (9th June, 2013)
  15. #13
    richard27's Avatar
    Aug 2011
    hello friend veri t5 write : 32 2A 86 9B C1 6F 15 A2
    YOU PiN : 17563
    temic immobox mc68hc05x16 (d62j)
    ​information sharing
  16. #14
    MACEDONIA
    Someone know formula for calculation?
