i also take an tunerpro XDF if anyone has one .
does anyone know where i can find the OE gruppe N Bin File for an s50b30 non ews?
I just put a set of Gruppe N Cams in my car and im in need for an OE tune.
Will it be possible to flash the ecu with an ADS connector from a yellow head? if not ive got a chip burner i just need to locate these file.
I have check Ista and several old version but nothing. i can seems to locate Gruppe N DME files.
this is for a Motronics 3.3
thanks for reading.
As far as I remember M3.3 can not be reflashed by diagnostic socket.
Can You post Your ecu numbers, it will help a lot.
Best regards
Kuba
I may make You feel, but I can't make You think...
ECU is Motornics 3.3 Without immo.
