why didnt you just swaped immo eeprom only from the beggining?
Hi all, I have a problem and I need a little help.
A friend owner of A4 TFS attempted to make chip from APR they use (UPD) programing sistem and we realy dont know way but the ECU, stay like as seen in the photos.
Carefully solved the problem of short circuit we can read all program with TRASDATA.
We bought a new ECU, and first top ut in the car, I read it as coming (virgin) and program the file (.dim) Reading with a trasdata from the old ECU and the car will not start ...
I replaced the virgin program and took the car to AUDI and diagnosis NOT RECOGNIZE the ECU ...
I returned to program the file (.dim) from the old ECU and if diagnosed and leaves programing in AUDI but when finished all steps and car will dont start ...
I do not know that I can do ..?
Thanks for all and sorry my bad English
Why not to do a ECU adaptation via AVDI ?
veloseeped :
Is not possible with simple methodes, with what methods if possible??
Ecu can be cloned using optican or x17 / T-boot, or immo off will work fine
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
ecutuners:
Thanks for the tip.
If OFF File INMO it works well, I can record with TRASDATA of DIMSPORT?
OFF INMO File as I can get?
Can be, for perform reprograming,ECU now inoperable forever..?
Same problem, what's the solution?
