File looks good to me. I am not expert. DPF is off.
2xded (5th June, 2013)
DTC off and switch...could work perfectly, test it
you've tried your file fap off?? I do not seem good ... write your result if you have tested
No, I did not try to write a file to the ECU. I want to be sure it is correct solution.
If this solution is wrong, I hope on help experts.
Unfortunately, I do not possess the necessary knowledge in this subject.
The file work if all sensors are connected and working, DTC tables are not modified in this file
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
blackpirate (5th June, 2013)
So if the DTC tables are not modified, does the DPF fault will reappear on dashboard but the car runs normally?
Unfortunately, I can not test this solution. Clone FGTech has failed and has been sent to his Chinese homeland for replacement.
test and advise !!!
2xded (13th June, 2013)
Thank you. This solution EcuSafe and I know it. Did you check it on the car?
