Results 1 to 15 of 17
    Default saab 2.2 tid PSG16 egr
    Hello! I have extracted file from tis for this saab end would need help with egr. Can someone checksumm these files? Thanks in advance file attached
    are you sure read is 100% correct?
    100% the file is extracted from tis and also from tech card 100% the same. First emtyed card then sps with tech2 and only thing it wrote was this. Also when extracted from tis2000 it came out the same.
    DK Veteran danielm's Avatar
    hi,
    With tech2 read 32MB and only 1mb maps engine.
    regards
    also extracted from tis and it was that size all tid files
    Jul 2012
    your file is not complete and you can not run the cks
    maybe you can just write the original file and you can not read in obd ..
    mettii original data in your ECU and find the file that you can write directly
    or read your file on bench
    LaraVAG's Avatar
    Jun 2011
    Can anyone know, how to export 1mb file from TIS 32mb file???
    I need file from 1500000 - 15DFF00.
  8. The Following User Says Thank You to LaraVAG For This Useful Post:
    Bllinda (14th July, 2014)
    Quote Originally Posted by LaraVAG View Post
    Here is your file.
  10. #9
    Jul 2012
    Quote Originally Posted by F4kk3r View Post
    Here is your file.
    which procedure to use for the size of your original file?
    how to export the file?
    the correct size for this type of file psg 16 is this
  11. #10
    LaraVAG's Avatar
    Jun 2011
    Quote Originally Posted by mario38 View Post
    Mario38 can you tell as how to correct export this file, and next import come back to 32mb file???
  12. #11
    Well rest of it just FF. HEre is the 1Mb file with "correct size"
  13. The Following User Says Thank You to F4kk3r For This Useful Post:
    LaraVAG (7th June, 2013)
  14. #12
    LaraVAG's Avatar
    Jun 2011
    F4kk3r, how did you export this file?? ctrl + c / ctrl +v ???
  15. #13
    winhex. But I think the 1meg is wrong because OLS gives checksumm error for it. I think the forst file is correct. Bytheway from what opel is this?
  16. #14
    LaraVAG's Avatar
    Jun 2011
    Its from Vectra 2.2dti.
  17. #15
    You can export the correct size file with winols, ecm, etc.
    Adress for export are from 1500000 - 15FFFFF
    Br.
