Check out this thread m8ty!
On multimaps, it's the numbers in the brackets that you use.
hi all ive got a new triax td110 with a dark motor , i have set the lattitude on the motor using multimap and me postcode which was 51.44421 so ihave set it to 51 is this correct
secondly the bracket that joins directly to the dish has a adjustable brack with some numbers on it im not sure what to set this at i guess its to do with the tilt of the dish
as i want to get this right as i live on the 5th floor
and because of the pigeon netting ive got to take down
as i have made my own bracket out of scaffolding , so i dont have to lean over and put a proper bracket on
thanks westkill
thats a good idea if the kids r bored they can always play with that spanner
Wow...well done if you get that aligned perfectly, that looks a right bitch to setup.
I just hope that pole is perfectly vertical .
