Results 1 to 10 of 10
    seba_m_'s Avatar
    Default DPF off Audi A3 1.9 TDi 105HP - 2009 year
    Hi Friends.
    Do any fellow will turn off the DPF from the driver, preferably manually. Volta and EcuSafe not do well this driver. Please help.
    Audi A3 1.9 TDi - 105HP
    03G906021AB - 395485
    Thanks.
    Aug 2012
    Default off
    Test and report
    seba_m_'s Avatar
    Thanks. I'll check and report.
    seba_m_'s Avatar
    Dump not work
    Aug 2012
    what is the Problem ? car smoke white ?
    All sensors connectet ?
    Nov 2011
    audi+a3.dat_dpf off.zip
    Dpf off switch solution
    Please report
    Babos's Avatar
    Mar 2012
    Good real pro!!! Swith solution please report back!!!
    What you made???
    Swith solution for damage ecu?
    And after we read new topic help please get back to life ecu.
    Best regards.
    Btw this forum for few tuners is traning place.
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by Babos View Post
    What you made???
    Best regards.
    I am not sure who you are complaining about.
    Is the dpf not a single switch at 1D3ED0.
    I am not professional so should I not help?
    seba_m_'s Avatar
    Problem solved, I was able to program the Volta. Already driven 1300 km is ok
    Diagnosticated is right. vag edc16 has 1 byte solution!
