Results 1 to 4 of 4
    Aug 2008
    Unhappy help for my starview 1 not updated
    i flashed my starview 1 with cryptstar v-1.5-core400 bin was succesfull and scaned all chanel atfer key emu on is not updated is writting updated 0% pls can you help want do do? key emu is on only free chanel is working
    V.I.P. Member camelv's Avatar
    Nov 2008
    dingle ,liverpool
    do a factory reset on your box m8 then set default then set emu to on then autoscan and then leave on sly sports 1 to update
    its the stuff we think we know that stops us all from learning
    Aug 2008
    THANKS CAMELV BUT HOW TO SET DEFAULT PLS
    Nov 2008
    dingle ,liverpool
    Quote Originally Posted by marseille View Post
    once you have fac reset m8 your first menu will be language ,press ok for english this should take you to installation menu ,key in 1570 and another menu will apear, scroll down to set default press ok, then scroll to set emu to on ,then press ok this should take you back to installation menu ,press ok on installation then press autoscan when it has finished leave on sly sports 1 to update.
    (could you turn your CAPS off please)
