Results 1 to 7 of 7
    May 2013
    Default can noy update my skybox f5
    hi evey one
    i am sure it is very easy to you why in f5 the dump by usb not highlight so i can not use it for update list or backup
    P&D's Avatar
    Hi silly question but have you put the usb flash pen in the back of the box ????
    if yes then it sounds like the usb port is ****ed
    The Stig PT mtv1's Avatar
    Apr 2008
    Tipperary
    is the usb stick in the box ??
    May 2013
    i did with the new update
    P&D's Avatar
    Sounds like the usb slot is goosed
    Apr 2008
    Tipperary
    can be easily replaced but if the box is new contact your supplier good luck mate
    May 2012
    I have noticed lately that the USB slot switces off if you have it in when you switch on. After uploading software on reboot the USB is usually off again and requires removing and replacing.
    When your in the tools screen put your USB stick into the unit, make sure its push fully home and see if the USB options highlight.
