Results 1 to 3 of 3
    Nov 2011
    friend and friend
    Default ford kuga mirrors, windows
    hello good afternoon dk, I can help a bit with this car, the issue is that it does not work the passenger window, I press the button to close the window and closed the mirror and then always listen centralized closures.
    fault diagnosis does not the only place that I can not get it in the companion module door.
    any idea say it is very common that in kuga: Azul:: Azul:
    Nov 2011
    friend and friend
    Hello I found the bug, the problem is in the engine control units windows, can you help want 93c86 original file. the driver and passenger door.
    ford kuga
    years 2008
    Nov 2011
    friend and friend
    thank you very much solved
