Results 1 to 15 of 17
    Above sea-level
    Default VW Passat 2.5tdi edc15 3B1907401B SW360452 0281010447 checksum problem
    Hi, can someone check the attched ori file of a VW Passat 2.5tdi? Somehow winols is not able to make the checksum. A good ori file would also be fine.
    File modified and isn't ori.
    Checksum OK
    Nov 2012
    smartville in front of a OBDplug
    i have same ecu in my passat tdi formotion
    Nov 2012
    you need ols 233 otherwise car no more start
    Above sea-level
    The file is 100 sure not tuned. At first I thought the file was not read properly, but I have already tried with 3 different tools.
    Above sea-level
    Quote Originally Posted by kennfeld View Post
    I have the ols233 file. Can you post your ori?
    Nov 2012
    i tested online in my winols the server answers that the good dll is ols 233 BoschV4.1 version 2.05
    Nov 2012
    Nov 2012
    Quote Originally Posted by budG60 View Post
    your file isn't original
    torque limiter advance egr maps all are tuned
    somebody make egr maps flat ...
  10. The Following User Says Thank You to kennfeld For This Useful Post:
    budG60 (25th June, 2013)
  11. #10
    You file is mod.
    This is the original file for this ecu.
    Br.
  12. The Following User Says Thank You to gezame For This Useful Post:
  13. #11
    Nov 2012
    yes automatic sw coding isn't an original 3011
  14. #12
    Above sea-level
    You are right!! Some egr maps (not all) are flat and it seems some maps are missing, which is probably the cause winols was giving problems. It is a little bit tuned I see now. Funny, because the owner of the car has the car for many many years and did not know this. Thanks for the help.
  15. #13
    Nov 2012
    yes but my official winols checksum work on this car you use ##### version ?
    the owner of the car if he use manual gear box sw 3012 then the mod's are not used in his car ....
  16. #14
    Above sea-level
    Have you tried to mod my file and correct the checksum without a problem? I have used the original file, tuned it and flashed it this afternoon and the car drives perfect. SW coding is 3011 (automatic).
  17. #15
    Nov 2012
    yes no problem to tune the file
