Results 1 to 13 of 13
    DK Veteran manocao's Avatar
    Default Autocom Delphi CDP+ Flight Recorder Solution Repair
    Self explanatory
    do when micro-sd card is not found by vci (Operation Failed:EraseFRArea failed)
    the problem is that card detection switch of micro-sd socket is not enabled in clone vci's
    after shorting solution, vci can work with or without card inserted
    just don't use flight recording functions if card is not inserted
    tested by myself with 2gb fat formatted card, works great, solved my problem
    of course i'm using 1230 firmware version, not 1232 or 1310 which are supposed to work bad with clones
    all credits to Dunker
    http://www.digital-kaos.co.uk/forums...ml#post1873277
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
  2. The Following 6 Users Say Thank You to manocao For This Useful Post:
    Col19 (17th November, 2019), mladen76 (21st August, 2013), paro44 (25th June, 2013), titoun (14th September, 2015), tolga07 (26th June, 2013), vasycara (1st December, 2013)
  3. #2
    Default Speaker Solution
    confirmed!
    it works with cheap piezo buzzer disc i recycled from a broken mc donald's child menu toy
    not too loud but i can hear the beeps and the music (5 tones) when using flight recorder
    notice how disc is suspended on air by tape
    btw, check that the flight recorder button is not always pressed because of the vci case, i had to use two washers around 2 of the screws so that button remains released until i press it
    __________________
  4. The Following 6 Users Say Thank You to manocao For This Useful Post:
    Col19 (17th November, 2019), gazvts (27th June, 2013), MJRVR (27th June, 2013), mladen76 (21st August, 2013), paro44 (27th June, 2013), titoun (14th September, 2015)
  5. #3
    Aug 2011
    Spalding
    Manocao
    Which toy was it?
    Martin
  6. #4
    don't remember, i just think it was yellow
    i just tore it into pieces and kept some components in the soldering box
    piezo transducer discs are very cheap, ask it in your local electronic dealer as piezo transducer disc 4khz (+- 0.5khz) 20mm diameter usually, with 2 leads, without built-in generator... cased version with a central hole beeps much louder... it just need not to be very thick, just some mm
    you can also find it in any item that beeps like shampoo promotion clock-alarm, alcohol breath tester, etc...
    __________________
  7. The Following User Says Thank You to manocao For This Useful Post:
    MJRVR (30th June, 2013)
  8. #5
    Quote Originally Posted by manocao View Post
    Why do you say that 1232 and 1310 not are good firmware versions for clon?
  9. #6
    i read a lot about firmwares after 1230:
    "The 2012.3 version when updating for internet the firmware change 1232. Firmware 1232 I do not recommend. But then you can upgrade and the firmware rewrite for 1230. recommend not to update the Firmware CDP, but update the software yes recommend.
    I updated my highest when the 1230 version of the rewrite again the 1230 version and the Autocom is saying you have the newest version. But I would stick with firmware version 1230 is stable Chinese clone. The 1232 gives problems like you do not Reconce VCI and weird things happened to me in a Chinese clone of 5 digits (CDP PRO) (20418, 30252 ...)"
    __________________
  10. #7
    Dec 2012
    cdp pro on firmware 1231 is not good but cdp+ firmware 1232 actually ok
  11. The Following User Says Thank You to gazvts For This Useful Post:
    Rai (2nd July, 2013)
  12. #8
    Default autocom cdp+ 1230 firmware
    i'm stucked on 1230 firmware whichever is the version of autocom/delphi 2012.3.3 or 2013.1
    how? extract 1230 firmware .rar into program files' firmware folder so that firmware is never updated when testing vci
    re-extract .rar everytime the software is updated via internet (2012.3.1 to 2012.3.2 and 2012.3.3) but i don't recommend updating 2013.1 to 2013.1.1 because patch is not ready for that version (avoid updating by renaming "wyUpdate.exe" to "-wyUpdate.exe" for example)
    __________________
  13. The Following 3 Users Say Thank You to manocao For This Useful Post:
    Col19 (17th November, 2019), koncimobil (6th July, 2013), miha99 (6th July, 2013)
  14. #9
    Default speaker solution
    smaller but much louder
    recycled from digital thermometer
    __________________
  15. The Following User Says Thank You to manocao For This Useful Post:
  16. #10
    Sep 2015
    Thanks to everyone is a great contribution, I will tell you if works for me
    Regards alexmetronia
  17. #11
    Feb 2012
    Greece
    can anyone please give link for recommended clone? (ebay prefered)
  18. #12
    Oct 2012
    Slo
    I had also the same problem with erasefrarea error. Tried the manocao fix still didnt work. After that i found out that the pins of the sd card didnt touch the card correctly when the card was inserted so i soldered the sd card directly to the pins (2Gb). After that i checked the pins and found also that the pin 3 from left to right (should be ground of the micro sd) didnt have a stable contact so i soldered a wire directly to the gnd. Now the flight recorder works
  19. The Following User Says Thank You to mkogej1 For This Useful Post:
  20. #13
    Nov 2019
    Did as you advised, after that the device stopped working, when connected to the car, the LEDs do not Shine. Checked fuses on 12 and on 5 volts both they whole but on them there is no nor 12 nor 5 volts.
    You have not encountered a similar problem, what could it be?
    I hope it's not a microcontroller.
    Can you tell me how it can be checked?
