    Jun 2013
    Default best router to use?
    What is the best router I can use for skybox f5? Or is there a tut to change settings on your router? I currently have sky broadband router
    digicon's Avatar
    Quote Originally Posted by rhysishere View Post
    The term urinating on your own doorstep springs to mind but thats up to your self, You cannot change the router when you signed into the agreement you also signed into using $ly's own equipment and they dont make it easy to retrieve the User and pass you need to use a 3rd party router, if you do get the info and use another one expect to have your service cut
    They won't cut your service if you're using a 3rd party router, i've been using an asus one i purchased for over 6 months, as long as you inform them before setting the router up with the details you retrieve through 3rd party programs then it's fine and you waive your right to technical support should a problem arise
    source - ex support for sky
    Jun 2013
    Good point about the doorstep, u can tell im a newb! If i split the phone line and use a different router will that work? Or is the line still sly's?
  5. The Following User Says Thank You to rhysishere For This Useful Post:
    digicon's Avatar
    The actual Line is still $ly's and runs through there equipment at the exchange
    Jun 2013
    Good job the wife signed up to talk talk earlier then thanks for help
