Results 1 to 5 of 5
    Default Audi Q7 dtc disable for intake manifold
    I need dtc disable for intake manifold.
    Ecu is EDC16CP34
    Dtc:
    12597 P3135 DUMP ADRESS:1CCB8A
    04120 P1018 DUMP ADRESS:1CCB92
    car run ok, only check engine light.
    test an report me. pass PM
  3. The Following User Says Thank You to 2010bastian For This Useful Post:
    gezame (26th June, 2013)
    Senior Member Diagnosticated's Avatar
    Mar 2011
    Quote Originally Posted by 2010bastian View Post
    If this is dtc fault path off method it may not work on this file. Did you switch off flaps or just dtc?
    nick_f's Avatar
    GR
    intake manifold problem in audi q7 is very common,i think instructions from for audi for this.
    Aug 2012
    LATVIA
    i hawe solution manualy
