Results 1 to 3 of 3
    Nov 2012
    Default How to program Proton waja Remote 2009
    Thanks in advance
    Fallen's Avatar
    Try one of these.
    GENERAL
    Procedure1. Remove the steering column cowling and take the transponder aerial off of the ignition barrel2. Use an un-programmed key to turn the ignition
    on, the LED will flash constantly or be on all the time (dependingon model)3. Turn the ignition off, the light will go out for 5 seconds and then flash or be on all the time (depending on model)4. Turn the ignition on, the light will go out for 5 seconds and then flash or be on all the time (depending on model)5. Using a key that is already programmed (or a chip from the VTI kit supplied with a new immobiliser), hold it insidethe aerial loop until the LED goes out.6. Turn the ignition off and remove all keys/transponders from the aerial loop, the LED will now flash or be on all thetime (depending on model)7. Re-introduce the pre-programmed key or transponder to the aerial loop, the LED will go out to indicate this key/transponder is now programmed8. The LED will again begin to flash/light up constantly to indicate further programming is possible. Insert the nextkey/transponder into the aerial loop and wait for the LED to go out. Remove the key/transponder from the aerialloop.9. Repeat the above step for all keys/transponders10. Exit the programming function by turning the ignition on and then off, the immobiliser will then be armed fornormal use
    JUMPBUCK, GEN 2 AND IMPIAN
    Procedure1. Switch the ignition on and press and hold the alarm reset switch usually on the centre console next to thefog light switch2. Switch the ignition off, remove the key from the ignition switch then return the ignition to "ON"3. Release the alarm switch and operate it once (the alarm LED should flash twice)4. Still with the ignition on, operate the lock button on the first remote, the alarm should sound once to confirm5. Still with the ignition on, operate the lock button on the second remote fob- again the alarm will beep once toconfirm.6. Switch the ignition off
    Note: All remotes must be programmed in this session as old one's will be deleted.
    Nov 2012
    Any other way ....
