Results 1 to 13 of 13
    Top Poster incar's Avatar
    UK
    Default Could we crack NAVI algo???
    After succes on Sony Gamma We could try with VAG NAVI!
    So far i know that Code is cripted in 3 identical strings on type SWA 10 20 30 and SWB old and SWC new 20 40 60
    What else???
    For compairing:
    SWB 0061 - 01 FF B7 50 B0 C5 CC 95
    SWB 0402 - 01 9F 77 E0 01 9E 8D 36
    SWB 1148 - 49 EF 37 A0 01 3E BD 26
    SWB 1168 - A0 9D 11 22 23 38 A3 2A
    SWB 1191 - A0 9D 8C F4 F5 0A 62 AB
    SWB 1276 - 6F 0F 4D 7C B9 D3 28 2D
    SWB 1289 - 6F DD FD A4 89 1E 8D 3A
    SWB 1556 - DC 41 20 85 AA E8 A0 C9
    Later i will add some more.
  2. The Following 3 Users Say Thank You to incar For This Useful Post:
    bonus2010 (3rd July, 2013), Car235 (3rd July, 2013), mohamad1401 (26th November, 2013)
  3. #2
    Dec 2010
    Russia
    Quote Originally Posted by incar View Post
    What a success ...??
    It's all nonsense ..! And it all wrong ..
    Algo completely different ..
    Why create a useless topic ..?
    Calc codes from serial FORD V-series from FORD dealer login
    bonus2010's Avatar
    Scotland
    Quote Originally Posted by mobilart View Post
    I don't know if sony algo different, but you appear to know different, perhaps you know navi algo?
    let all members post strings of known codes of navi algo, and we all work together
    remember, a MAN worked out this algo....... that means it is not impossible!
  5. The Following 2 Users Say Thank You to bonus2010 For This Useful Post:
    mohamad1401 (26th November, 2013), nelutzul40 (3rd July, 2013)
  6. #4
    Dec 2010
    Russia
    Quote Originally Posted by bonus2010 View Post
    10,000 lines .. it is not possible ..
    POLAND
    0061 01 FF B7 50 B0 C5 CC 95
    0136 71 79 8E 37 F1 50 7A 44
    0203 A1 09 81 BA 9A 6F 46 EB
    0239 71 6F 51 69 11 4E ED A5
    0263 71 0B 57 5E 7E 1F 66 25
    0290 01 9B C3 8C 8C D9 28 61
    0368 71 3F 47 E8 92 21 A2 53
    0440 01 9F B7 80 E2 C0 18 61
    0402 01 9F 77 E0 01 9E 8D 36
    0510 D1 F3 E7 80 01 DE DD 26
    0541 41 7A C2 2A 81 E5 7B 9A
    0578 01 66 36 7F 1A F4 68 30
    0615 01 09 8B 26 1E 2B 61 88
    0652 E1 B3 92 97 46 51 0B 1D
    0720 B1 BF 37 B0 AA F9 CA 43
    0733 B1 BF 07 40 6A B9 BA C3
    0750 01 0F 84 4D 3F 1A 6E B4
    0844 01 DF F7 00 22 80 58 21
    0866 01 DF 53 B8 DA F0 20 31
    0986 E1 8F 97 5A 9A 9F 66 E9
    0988 51 37 97 E8 22 19 2A 1B
    1148 49 EF 37 A0 01 3E BD 26
    1168 A0 9D 11 22 23 38 A3 2A
    1191 A0 9D 8C F4 F5 0A 62 AB
    1276 6F 0F 4D 7C B9 D3 28 2D
    1362 3E A6 1A 57 0C 8E C2 FA
    1556 DC 41 20 85 AA E8 A0 C9
    1591 DC 41 4C F0 E1 BE 46 CF
    1844 0D 2B A3 0C C6 F5 86 4B
    1854 0D D3 E7 EC F1 66 D9 A9
    1917 7A 99 EA 74 51 5B AF 70
  8. #6
    POLAND
    We have a 1st digit of code , you should 2st byte
  9. The Following 2 Users Say Thank You to kazek123 For This Useful Post:
    bogege (3rd July, 2013), Car235 (3rd July, 2013)
  10. #7
    smoggy's Avatar
    Apr 2009
    UK North East
    I've been trying to crack this one for a long time and to be honest I don't know for certain which Bytes/Nibbles are actually used in the calculation.
    I have over 200 with known codes
    take a look at these two where only the last byte changes
    01 5F 37 C0 C0 B5 BC 21 code 0308
    01 5F 37 C0 C0 B5 BC 85 code 0581
    EDIT : also
    01 5F 37 C0 C0 B5 BC 85 code 0308
    81 4F A7 30 30 05 EC B5 code 0308
  11. #8
    POLAND
    Navi ----- 1------
  12. The Following User Says Thank You to kazek123 For This Useful Post:
  13. #9
    POLAND
    EDIT : also
    Can anyone confirm this because it explains a lot
  14. #10
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by kazek123 View Post
    EDIT : also
    those codes were given by the master so I have no need to doubt them
  15. #11
    smoggy's Avatar
    Apr 2009
    UK North East
    What I've also found is whatever the first nibble is somewhere in the code there is a linked digit and when you Xor the two it always gives a 0-4-8-C a bit like the sony algo
    and this applies to all the dumps I have where the first digit of code is 0
    as an example if first nibble is 7 somewhere in the code there will be a 3 and Xor 7 with 3 = 4
    CODE DIGIT...... 0 1 2 3 4 5 6 7 8 9
    1st NIBBLE .......0 D A 7 4 1 E B 8 5
    Xored ..............0 C 8 4 0 4 8 C 0 C
  16. #12
    UK
    Quote Originally Posted by smoggy View Post
    EDIT : also
    Ok, but how about versions??? Maybe this is the case of SWB SWC ??? Are strings from same line??? If it is frome same line, as far as i know ther is two versions of encription.
    Could you post these full dumps? I might check that.
  17. #13
    smoggy's Avatar
    Apr 2009
    UK North East
    I don't have the dumps, I just took the info from them but all the dumps are somewhere on this forum if you search.
    I don't know if there are two different versions of encryption or is it like sony gamma where you can have different hex bytes but they calculate the same code
