if your tool is original why not write direct to MagicMotorSport to receive support.
here you will get something but not official support!
Because i have***324;t renew magicmotorsport assistance
it will cost you probably about the same amount of money to fix the problem now.
Chiptuning fanatic - FILE SERVICE 24/7! Chiptuning / Dpf off / Egr off / DTC off / etc.
Bapro 4x4 dyno + SP6
Flex / X17, Autotuner, Bflash, NewGenius, FGTech, HPTuners, BitBox, PCM Flash
Magpro2 assistance is 800 euros by year, you think i need 800 euros to solve the problem?
hi, where is the ecu? bosch type?
you write the ori file , and same problem??
Is the message security mode activated on the cluster? Or in the fault/event memory?
If its on the cluster you have a CAN fault problem
If the message is being displayed on the COMMAND unit you with need the pin re entered with STAR
If its in the event memory(not fault memory there is a difference), disconnect the battery for 15 mins
What engine is this? Om651
elcarpuz (9th July, 2013)
I test a MOD file with DPF OFF, now, no MIL, no DTC in memory but always no power
what is the solution
hi
Original asks that bdm ecu and write it by bdm, with bdm no nothing problem.....with obd2 more problems with this vehicles.
How can i do now?
read by bdm?
I read on other forum very difficult to open this type ecu without damage it
i think your dpf file was done with volta or ecu safe thats the problem . this tools delete the most dtcs no good solution upload the original file . i think your problem is in eeprom
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
elcarpuz (10th July, 2013)
M8, New ecu will be more expensive than subscription, you will expend the money y a new ecu and will still without asissistance.
I think you should pay for subscription and ask for unlock file to magicians.
At the end with the same amount of money you will get more results.
Regards.
you can find spare ecu on ebay for cheap if you have a backup of your ori it's not a problem to deal with ecu as many people used to say.
what ecu / engine it is ?
It's edc16c31. 204hp, any solution?
