Results 1 to 15 of 24
    DK Veteran elecautocr's Avatar
    Default BMW E46 320d DDE3 error #42 (eeprom or coding)
    Hello members:
    I have a problem with BMW E46 320d ECU. The car don?t start, it cranks but no start, I have error code #42 (eeprom or coding). I am attaching dumps of ECU. Can any of you check if the dumps are corrupt or checksum error ?
    Thanks very much
    Sep 2012
    Your ISN is: BA 79
    I will try to get you another EEPROM dump, I will check your EEPROM shortly.
    Sep 2012
    Please try the attached EEPROM
    Jun 2013
    hi enigmauk give me pasword ***305;cahck file please
    Sep 2013
    garage
    i have a bmw 320D DDE 3 ecu with this error , car is cranking but no start ...what cause this error and how to fix this ?
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Quote Originally Posted by Mr BLACK View Post
    First read DTC and post here.
    Here to HELP!
    Sep 2013
    garage
    42 (eeprom and Codind) is main DTC ,i write eeprom 24c02 with virgin state but same error this DDE3 ecu have 2X 27C010 OTP eeproms and i think that somehow code inside is damaged or cpu is not able to read correct content, i try to read this ecu with MPPS but i only get 32K o data out of it...
    dimitar's Avatar
    The eeproms are flash not OTP. Reprogram with beeprog or similar and make virgin
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Sep 2013
    garage
    see 27C010 datasheet they are OTP not flash
    dimitar's Avatar
    plcc32 28f010 , yesterday screwed up one dde3 with winkfp and repaired with beeprog. Original eeproms must be flash otherwise you wont be able to update software in dde, perhaps yours is first generation dde3 wich cant be updated. just gues
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Sep 2013
    garage
    yes is a old ecu ...if is no solution , I think I'll buy a used one and program 24c02 eeprom with a virgin dump
    bram380's Avatar
    Indonesia +628153111774
    WinkFp tips:
    Uncheck option UIF Program.
    Now you can program DDE/DME many times.
  13. #13
    Sep 2013
    garage
    this error #42(EEprom OR Coding ) is caused from 24c02 eeprom, i reprogram a new 24c02 eeprom with a dump from D.K and error is gone but immo is active , and when I program a virgin dump configuration is missing,(eeprom OR CODING) so this error it leaves room for interpretation,
  14. The Following User Says Thank You to Mr BLACK For This Useful Post:
    DomnulNegru (15th February, 2016)
  15. #14
    Oct 2015
    hi i have also the same erroron e46 320d 04/1999 i was trying to copy the adjustment values from another same dde done but cant start the car i draged the car with another one the car started very good working but when i tryid to restart the car no luck just smoke and nothing else so i have a file from the new ecu that i bought its similar to mine but can someone make it virgin the whole data so i can flash it with mpps so it works im not good at this type of things but i have inpa ediabas dissv44 dissv39 sss dissv55 mpps delphi ,delphi is the one who screw up ,diss v44 tryis to program it ends up with an error that cant mesure something so this is the file you guys are good at this pls help 42 DDE Error -EEPROM or Coding ;;;;;;;;;;;;;;;why i cant add the file
  16. #15
    Oct 2015
    Quote Originally Posted by ilirii View Post
    i dont know why i cant attach the file but pls send me a email to**********so i send you the file thanks
    Last edited by Johnner; 1st October, 2015 at 10:02 PM. Reason: No Email Addy's please !!!
