FGTech2 0050-0103 clone run problem -- help me!!
Results 1 to 2 of 2
    Top Poster Africa's Avatar
    10
    Downloads
    214
    Uploads
    Default FGTech2 0050-0103 clone run problem -- help me!!
    help, my interface not working!!
    select model, I give you identify, or read, ... indicator bar to reach 100% automatically exit the program without reason. Someone happened to him?
    I thought that might be the fgtech eeprom, and have restored some times .. But do not get results.
    you can upgrade to more modern?
    eeprom attached my FGT2 to test it.
    ..............Thank you. ...
    Original BDM EVC with adapters, SPI EVC, Galep5 programmer, emp11 programmer, upa1.3, kwp2000plus, MPPS, Ktag, Kess, Galletto ofiicial, and many more...
    10
    Downloads
    214
    Uploads
    solved. failure was a problem with my computer.
    HD formated, reinstalled everything and ok.
    the eprom that attachment is ok, are those of 0050-0103. (This carries a USB hardware-key).
