Results 1 to 13 of 13
    Default need code radio BLAUPUNK NISSSAN MICRA
    hello
    some one can find the code of this catr audio
    Nissan mm cd-J
    BP234732051168
    7 642 347 318
    i find the code(calculGen 2009) 1903 for renault calculation if i put the code 3472051168
    how i can valid the code if the code is good what is the good key?
    thank in advance
    regard
    try code 4050
  3. The Following 3 Users Say Thank You to osman ?elebi For This Useful Post:
    bogege (13th July, 2013), newgeniehex (13th July, 2013), smoggy (13th July, 2013)
    smoggy's Avatar
    Apr 2009
    UK North East
    .........code is 4050
    EDIT : I was too slooooow
  5. The Following 3 Users Say Thank You to smoggy For This Useful Post:
    bogege (13th July, 2013), newgeniehex (13th July, 2013), osman ?elebi (13th July, 2013)
  6. #4
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Code is : 4050
  7. The Following User Says Thank You to Faraday For This Useful Post:
  8. #5
    Bulgaria
    A little help for entering the code:
    Nissan MM CD-K
    Blaupunkt 7 642 347 318
    As originally fitted to the :
    Nissan Micra
    If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
    Code Entry as Follows:
    Switch Radio On - Display Shows
    " CODE " Then " 0000 "
    Press preset " 1 " repeatedly for 1st Digit
    Press preset " 2 " repeatedly for 2nd Digit
    Press preset " 3 " repeatedly for 3rd Digit
    Press preset " 4 " repeatedly for 4th Digit
    If the correct code number is now shown
    Press Tuning Up Button " ^ " To Enter
  9. The Following 4 Users Say Thank You to bogege For This Useful Post:
    Dekster (11th April, 2020), newgeniehex (13th July, 2013), osman ?elebi (13th July, 2013), smoggy (13th July, 2013)
  10. #6
    hello
    the code is ok!!!!
    i have read the the eeprom 24c16 and i find too 4050 and i have reset the conter!!!
    big tank to all
  11. #7
    Dec 2013
    Hello i need a code for my nissan micra bp radio
  12. #8
    smoggy's Avatar
    Apr 2009
    UK North East
    Quote Originally Posted by DejanJov View Post
    check your other post
  13. #9
    Apr 2020
    Hi. I need a radio code Nissan Micra
  14. #10
    Apr 2020
    Such information on Radio panel: BLAUPUNKT BP738387797731. E1 034173. NISSAN MMR#2CD 7647383318
  15. #11
    Dekster's Avatar
    Dec 2012
    POLAND
    Quote Originally Posted by kostevko View Post
    ................ 2243
  16. The Following User Says Thank You to Dekster For This Useful Post:
    bogege (11th April, 2020)
  17. #12
    Apr 2020
    Thanks a lot. My code is 2243?
  18. #13
    Bulgaria
    Yes! This is the code for the serial number you wrote.
