Results 1 to 6 of 6
Hybrid View
    Administrator
    Devilfish's Avatar
    Feb 2008
    Default Lost grub after reinstalling windows?
    I'm sure someone will know this...
    I had dual boot Ubuntu 7 and Windows XP. I reinstalled XP and now I've lost the grub boot screen. I've googled it and there's quite a few ways to get it back and they all seem longwinded.
    Does anyone know a simple way to get it back?
    Thanks!
    V.I.P. VIC
    Mjolinor's Avatar
    Jan 2009
    Burnley Vicshire
    Late reply
    If you haven't sorted it then google "grub 4 dos" and try that, if you have any problems post again.
    Its really easy with grub for dos, no need to mess with the MBR, it's all done from the WIndo$e partition.
    May 2009
    Junior Member kari's Avatar
    Sep 2009
    Finland
    Quote Originally Posted by Devilfish View Post
    Thanks!
    simple way to get it back is use super grub disk you find it here
    Super Grub Disk Helps Linux Newbies Fix The GRUB (Boot) ~ Web Upd8
    Sep 2009
    Finland
    If you don't have or can't get super grub disk use this
    1) Boot off the LiveCD
    2) Open a Terminal and type in the following commands, noting that the first command will put you into the grub “prompt”, and the next 3 commands will be executed there. Also note that hd0,0 implies the first hard drive and the first partition on that drive, which is where you probably installed grub to during installation. If not, then adjust accordingly.
    sudo grub
    > root (hd0,0)
    > setup (hd0)
    > exit
    Reboot (removing the livecd), and your boot menu should be back.
    Only read below if Windows is now missing from the boot menu
    If you installed Ubuntu before you installed Windows, then Ubuntu will not have anything in the grub configuration for Windows. This is where you’ll have to do a bit of manual editing to the grub boot menu file.
    If you open the file /boot/grub/menu.lst with the following command:
    sudo gedit /boot/grub/menu.lst
    You’ll see a sample section for Windows, which you’ll want to uncomment and add to the boot menu list in whatever position you want it in. (uncomment by removing the #’s)
    # title Windows 95/98/NT/2000
    # root (hd0,0)
    # makeactive
    # chainloader +1
    Note that you should also verify that hd0,0 is the correct location for Windows. If you had installed Windows on the 4th partition on the drive, then you should change it to (hd0,3)
    Member grizzlyt's Avatar
    Oct 2008
    You can easily download Partedmagic with Unetbootin then install it on a USB Stick.
    There are all utilities that you need on it.
    Latest release yesterday: version 4.6
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
