Results 1 to 15 of 20
    DK Veteran VTS_Tibi's Avatar
    Hungary
    Default TMS28F512 - what chip to use in place? (Marelli IAW. 1AP 10)
    Hi Guys,
    In the future I will have to tune a few Magneti Marelli IAW 1AP 10 ECU found in the Xsara VTS / 306 GTI6 2.0 16V.
    Most of these ECUs come with a TMS28F512 some with an ST28F512, and I also have two which have been remapped previously, using an AT27C010.
    I have a Willem GQ-4X to do the job, which can't do the TMS28F512, so I'll have to find a chip to replace this.
    What kind of chip could replace this - preferably one which can be rewritten loads of times!?
    Thanks,
    Tibi
  2. The Following User Says Thank You to VTS_Tibi For This Useful Post:
    paskizo (19th March, 2019)
  3. #2
    Hungary
    Any clue about this guys?
    mexanico1971's Avatar
    portugal
    one time I have found 29f010 in the place of the Tms 28f512 !
    on peugeot 106 gti 120cv !
    but never try to do the same !
    I have some 28fxxx from the ecu I fix, in case of need !
    but I found this ones on ebay !
    TI TMS28F512 ?12C3FML 64Kx8 Flashable Eeprom | eBay
    regards
    My work is my life ART TECH GARAGE
    Hungary
    Well, I would need an other brand, like ST, as my Willem can't do the TMS
    Jun 2013
    EU
    Treat it as Intel 28F512 and you will be happy.
    Hungary
    Quote Originally Posted by morgano View Post
    Tried it and no luck unfortunately
    portugal
    some time I have found this one on ebay but not order yet !
    CATALYST CAT28F512N 28F512 FLASH MEMORY PLCC32 X 10pcs | eBay
    what willem do you have ?!
    PCB or the one in the BOX fancy ?!
    Hungary
    Quote Originally Posted by mexanico1971 View Post
    The GQ-4X (the one already made with the white box)
  10. #9
    portugal
    hum !
    I use the PCB 3.5 version !
    sorry ! do not know how to help more !
    regards
  11. The Following User Says Thank You to mexanico1971 For This Useful Post:
    manutec (13th May, 2020)
  12. #10
    Sep 2010
    gq4X work 100% with 28F512 any brand
    you can use any 28F512 or 27C010 or 27C1001 , or 29F010 or 29F1001 or 27C512 you have the choice
    please be sure your gq4X is up to date check newer soft .
    on gq4X soft try with other 28F512 and check your adapter contact
  13. The Following User Says Thank You to gzk For This Useful Post:
    laki23 (25th October, 2018)
  14. #11
    Netherlands
    You can't replace a 28Fxx by any 27cXX eprom the pinout is different.
    You can use a 29F010 for 28F512 by connecting pin 2 and 3 togheter and program 29F 2x with the same file.
    Be sure to use a proper 32p PLCC to 32pin DIP adapter to read/write the 28F512.
  15. The Following User Says Thank You to easytech For This Useful Post:
  16. #12
    Nov 2012
    smartville in front of a OBDplug
    i did lots with 29F010 never got problem
    the other i do them all over obd ... with the spi system
  17. The Following User Says Thank You to kennfeld For This Useful Post:
  18. #13
    Sep 2010
    Quote Originally Posted by easytech View Post
    Sorry but you wrong .
    what i have write is from my personnal experience on peugeot and citroen old ecu and msa15 tdi ecu .
    is not write i have read or heard by another one , so i can certified 100% that it work ,
  19. The Following 2 Users Say Thank You to gzk For This Useful Post:
    paskizo (19th March, 2019), VTS_Tibi (25th July, 2013)
  20. #14
    Quote Originally Posted by gzk View Post
    To replace 28F512 with 27C010 or 27C1001 (and 29Fxxx) are possible BUT NOT with 27C512
  21. The Following 2 Users Say Thank You to Zmann For This Useful Post:
    paskizo (19th March, 2019), VTS_Tibi (26th July, 2013)
  22. #15
    Netherlands
    @Kennfeld
    I find it hard to believe you can flash the 1AP10 by OBD with a 29F010 flash.
    The 29F010 has 5v programming voltage and the 28F512 12.5v.
    I made this mistake myself 1 time and also blown an OLS300 emulator in the past.
    And yes indeed 27c010 should also be working.
    I should even be possible to program it in circuit but never tried.
  23. The Following User Says Thank You to easytech For This Useful Post:
