pintobraz (26th October, 2014)
Hi!!
Today I was plaiyng with a Marelli IAW5AMHW610 and my MPPS. It was not the first time and before today all the operations were OK (read/write, cecksum, etc.).
So, I wrote a map for a Hypermotard 1100 Ducati. Bike doesn't start... engine turns but wuldn't start. I start with a dignosis (using VDSTS from Technoresearch): there were non error in the ECU, but when I try to test the coils I had a surprise!! Coils command where inverted: vertical instead horizontal. I inverted the spark plugs and the engine starts .
I try to re-write the old map, but the result was the same.
The file I wrote in the ECU, of course, was super-tested in the past and used on other ECUs with no problems.
How it is possible? Is there a way to bring the ecu to a "virgin status" with no controls inside the flash and the e2p so I can rewrite and restore it?
This is the file I wrote in the ECU:
Hyp2008.rar
Thanks in advance
M999
I would not puzzling why ...
I'll just swap two wires for the coils in the connector on the controller.
I know that is not professional, but sometimes you have to improvise ...
Cheers!
Yes, this is an "hardware" solution
But I would like to go back to a standard situation. I think that the coils controller is in the e2p area of the software that I downloaded using MPPS (the first 4000 address of the map). Probably there is a bug during the upload of the map in the ECU and there is a "wrong correction" of this area.
Do you know a way to bring back this ECU to a virgin status, with no software inside (also in the flash and in the e2p)?
Thanks!
M999
Personally, I don't know how... sorry!
