Skybox F3 e001
  • Tal1481
    • Jun 2009
    • 18
    Skybox F3 e001
    I updated the firmware on my SKY F3 box due to glitching - now all I get is an E001 error.
    I have used a NULL modem cable and it upgrades using firmware from the official skybox website and from the Yuji website and have also tried the scooby snacks firmware but I can get nothing to work. I can get it to flash with no mismatch error and even though it is reported as succesfull the following just keeps happening:
    When the box is turned on it gets to 93% and then I get an E001 error.
    Like a moron I didn't take a dump of the firmware that originally was loaded and worked.
    If anybody has a fix - please post a link or PM me - I have spent hours trying to sort it.
  • Dazzle1
    • May 2013
    • 11
    What procedure are you using the null modem?
    • Dazzle1
      • May 2013
      • 11
      Sorry let me write that again:
      What steps are you using when you are using the null modem cable?
      • P&D
        • May 2010
        • 2684
        Originally posted by Tal1481
        silly question but when you say "I can get it to flash with no mismatch error and even though it is reported as succesfull"...are you burning the flash to the box ?????......1st screen with the flasher means the firmware is uploaded (not flashed) after the 1st screen you need to download to the box which takes 4-5 min's
        What flasher are you using ???
        try this one ........erom_upgrade_8Mflash this one worked for me.....
        use this firmware ....SB.abs (thx to dmaster2000 for the file & how to)
        Hello everyone, I recently tried to upgrade the firmware on my f5 using the usb method but when it finished flashing the box would not boot up. It would load to 93 and come up with E001 error.
        I've looked everywhere for a fix and tried so many firmwares and programs to bring my box back to life!
        FINALLY after trying and trying different programs and firmware, my skybox f5 is fully working!
        The following is a step by step solution. You require rs232 null modem cable, and the following downloads:
        both file at the bottom of the listing
        1. extract the file erom_upgrade_8Mflash wherever you want and open the folder. Also extract the firmware file SB.abs
        2. Open the application EromUpgrade
        3. Select the port your null modem cable is connected to. (if you dont know which port, open devicemanager on windows and scroll down to ports and here you will see something like COM1 for example)
        4. Select bitrate: 115200 and Parity: Even
        5. Select Operate Mode: Upgrade
        6. Now in File, Click browse and select the extracted file SB.abs
        7. Connect the null modem cable to your skybox, and disconnect the power supply.
        8. Click on next and you should now see Please reset target.
        9. Connect the power supply and the firmware will start downloading. If it hangs for few minutes you can cancel the download and start again. Keep trying till it gets to 100%.
        10. After it is downloaded click next to burn the firmware.
        Once this is complete you should have your skybox back to life!
        • kaisar1
          • Aug 2009
          • 462
          what has the firmware got todo with glitching mate?
          glitching more than likely is to do with server.
          • P&D
            • May 2010
            • 2684
            Hi mate try reading the post Tal4181 posted
            "now all I get is an E001 error" which i believe is a firmware issue
            • errguapo
              • Jul 2013
              hi i get same problem like you but i make before a backup to my original firmware so i put it again and work fine again
              i hope it will work with you
              • brin251
                • 122
                If this is the f5 you wont be the first or last to experience this shudda gone f3 well steadier
                • elmoemo
                  • Jan 2012
                  • 17
                  i have this problem with f3
                  • BrunoJ
                    • Jul 2013
                    • 141
                    Hi guys i been try loads a option for the last 3 days some firmware the box keep loading over and over again , some stuck on load at 93, some at e001 any ideas ?? thanks
                    • P&D
                      • May 2010
                      • 2684
                      Try booting the box with no cables attached
                      apart from the power cable
                      • MyB5
                        • 49
                        You're so right......best programs and solution/instructions. Thx a lot!
                        Vu+ Duo-BH 2.0.9,1
                        CloudIbox II+
                        DM600PVR & DM500
                        Skybox F5 & F5s
                        Oscam 9533 & CCcam 2.2.1
                        0.8/ 4.8/ 7.0/ 13.0/ 16.0/ 19.2/ 23,5/ 28,2
                        Scandinavian
                        • bruno40
                          • Nov 2010
                          how do i download file
                          • strawmen
                            • Mar 2014
                            • 3
                            Anyone can recommend a null modem that will work with an F5?
                            • Hadron
                              • Nov 2012
                              • 2102
                              #15
                              I haven't actually used this one myself, but it should work OK:-
                              2m Null Modem Cable - Lead RS232, DB9 9 pin Serial Comm | eBay
