Results 1 to 13 of 13
    felix_fetche's Avatar
    Nov 2009
    Baia Mare
    Default Autocom (new 2013) VCI Interface Issue
    hi,
    usualy when plug to OBD (power it with 12V) the blue rectangle has to be shown on as a selftest of the computer inside the interface.
    but mine does not turn on any led when plug to 12V, but if i plug then the USB to the laptop it`s showing red light rectangle,
    the virtual COM port is prsent (the FTDI) but when i try to test hardvare red is blincking and software is returning the message " No VCI Found"
    that means the MCU inside interface does not reply.
    does anyone here is having the same experience or issue as mine? i have allready two cables with same behaviour.
    what is the receipt of the remedy ? is it hardware failure or the MCU does not boot and has to be refirmwared by JTAG?
    i say thanks in advance!
    dopsleutel13's Avatar
    Aug 2009
    Dutch
    Ok open the VCI and look for burn / melted tin contact's .
    What did you do before ? Updade flash or what ?
    Nov 2009
    Baia Mare
    look,
    i close all okay, i unplug and put it on the desk, and next day on another car simply dont light up blue leds when plug in OBD.
    Aug 2009
    Dutch
    If you have tryed on another car and still nor working then open it and look foor bad contac's .
    i heard from other same complains and find lose contact and some chip are broken .
    Nov 2009
    Baia Mare
    please be more specific
    Dec 2012
    Can you post a pic of the vci
    what dopsleutel13 is asking you is to dismantle the vci (4x screws) take out the pcb board check it for poor or broken solder
    when connected to 12v only and not usb there should be power cdp+ ( blue leds or red if vci is bricked/ dead) you dont so board is not getting 12v
    if you only purchased this unit recently ship it back to 1 dodgy seller register a dispute with paypal
    Nov 2009
    Baia Mare
    please,
    have you ever see the rain, on a sunny day?
    stay close to the subject, NO BLUE LIGHT WHEN PWR ON [plug on OBD of any car], but after this connecting USB, RED regtangle does show up.
    Dec 2012
    Quote Originally Posted by felix_fetche View Post
    please,
    you need to open an check pcb for broken parts or just take the chance buy a st-linkv2 and
    you can jtag the vci look for user Zmann he has posted up a dump file for stm32 mcu to reflash
    As i am not near or on pc to upload any
  9. The Following User Says Thank You to gazvts For This Useful Post:
    carpin (18th November, 2013)
  10. #9
    Nov 2009
    Baia Mare
    sounds pretty close to the subject. i will try to find Zmann`s job.
    what hardware i need as jtag programmer? i dont have any jtag at all.
    in the far past i was using some jtag to reflash motorola startac phones
    to change language package, but it was 15 years ago, the interface is lost from years.
  11. #10
    Dec 2012
    Any programmer that supports arm stm32 mcu 32bit here's 2 dump files from Zmann's for a st-linkv2 programmer
    don't use 2013.1 = crap
    use 2012.3 software stable
  12. The Following User Says Thank You to gazvts For This Useful Post:
    micromax (15th January, 2014)
  13. #11
    Nov 2009
    Baia Mare
  14. #12
    Dec 2012
    this is the way i did it was just to keep neat (plug & play)
    one 2x5 pin smt hardwin header (in pic above just to make it easier for future use)
    one female 2x5pin header to solder jtag wires to for pcb
    one female 2 x 10pin header again to solder jtag wires for st-linkv2
  15. #13
    Nov 2009
    Baia Mare
    the ease way is to solder the boot wire, then power on again to enter bootmode for flashing with ST flash demonstrator from ST site.
  16. The Following User Says Thank You to felix_fetche For This Useful Post:
    gazvts (20th November, 2013)
