Results 1 to 7 of 7
    Hungary
    Default Honda CB 1000 R Lost keys
    Hi!
    Please help me with this bike:
    Honda CB1000R year 2008
    ECU Keihin 38770-MFN-D01
    8840-107567
    I have lost all of keys.
    Can somebody help to virginize dump from ECU please! (93c66)
    93c66b-16bit-38770-MFN-D01.rar
    Many Thanks...
    Pite3.
    gwee's Avatar
    Dec 2012
    unknown
    reset dump for 2 keys
  3. The Following User Says Thank You to gwee For This Useful Post:
    pite3 (22nd July, 2013)
    igorr's Avatar
    Aug 2010
    All position of keys are the same,you can find here on DK many dumps 93c45,956,66 and when you compare wit orginal you will see where you nead to put FF ,and job done
    Thanks to IEA for simple solution
  5. The Following 2 Users Say Thank You to igorr For This Useful Post:
    gwee (21st July, 2013), pite3 (22nd July, 2013)
  6. #4
    Hungary
    thanks for help.
    try and report...
    Hungary
    Dump works perfectly!
    Thanks gwee and thanks igorr!
    Pite3.
  8. The Following User Says Thank You to pite3 For This Useful Post:
    gwee (23rd July, 2013)
  9. #6
    gwee's Avatar
    Dec 2012
    unknown
    Thank EFFI !!
    Order one, it will be very useful to you
  10. The Following User Says Thank You to gwee For This Useful Post:
    weza247 (9th December, 2016)
  11. #7
    Oct 2017
    Hi guys, I've got an Honda CB 1000 R ABS 2016 (European model - Italy), can you please help me to understand how to read, modify and wrtie my ECU?
    Do you have the definition file of the bin?
    I'm able to read the diagnostic data via DLC connector (k-line) using a self made "gadget" based on Arduino and I'm pretty sure we can read/write the entire ECU firmware from DLC connector but I need the command to send via k-line and obviously the definition file.
    Thanks!
