Results 1 to 3 of 3
    NASTASE's Avatar
    ROMANIA
    Default Problem reading Mini Cooper R53
    Hi all,
    Need an advice.Try to read Mini Cooper S R53 with MPPS,bad file read only 183kb.
    Read with Galletto,but no ECU data-strange-, file OK 512kb.Software has been bad modified by the previous owner.I found noread protection tag,I removed protection,restored the ori file and try to write back with Galletto, but the interface refuse to write.Both interfaces are tested and works perfectly.
    This is file found with noread protection tag:
    COOPER S read Galletto.rar
    This is same file but without read protection:
    COOPER S WITHOUT NOREAD TAG.rar
    Any help is welcome,thanks in advance.
    Real engines don't need forced induction
    Who needs a turbo when you have a stupidly quick naturally aspirated engine?
    Your file are cks not correct.
    Test this file.
    Br,
  3. The Following User Says Thank You to gezame For This Useful Post:
    NASTASE (22nd July, 2013)
    NASTASE's Avatar
    ROMANIA
    Thanks Gezame, I'll try and report until the end of the week,car is 200km away.
