EGr off is easy 1 byte switch off. and i think volta does EGR ok on this one via hysterisis
can somebody help me to make EGR and DPF off in this Ori file ??
i try Ecusafe and Volta but doesnt work good, i think swiftec make this job better.
398784_edc17cp14_ori.bin.rar
rgds Toby
work with :
EVC Winols 3.32 , Swiftec Full V1.9.1.6 , ECM Titanium V1.73 , New Fgtech Galletto 4 Eu V54 and V54 Mini High End , Mpps V18 , Byteshooter Truck V4.0 , Vag K+Can , Vag Tacho V5.0 , Alientech K-Tag V2.12 , MRM Rns Manager 6.55 , VCDS AI 14.10.1 , VAGDashcan 5.17 , VCP Can Pro , Magic Motorsport Magpro 2 , X17 , Password Plugin !
Ok,then maybe my egr is not ok ,maf shows wrong values in vcds with volta deactivated egr. ??
Do you still want DPF off on this one?
yes should show strange values!
You can also modify the MAF (egr ) map... to ajust flow and calculation of MAF according to EGR position
Here is your file, DPF+EGR off.
Password in PM
tobygolf66 (21st July, 2013)
Your PM inbox is full, clear it and then I will send you password.
work with :
Sent.......
