Results 1 to 12 of 12
    Jul 2013
    Default help with carprog
    hey everyone, i picked up a carprog full with all wires etc.... I am using the a6 cable and have have it connected to the 95160 chip but when i hit NEXT on the carprog v5.77 i get an error of some type "File 081105CAR001773I.lib not found" im pretty sure that my unit is a clone also.
    Thanks for any help in advance
    Cheers Darryl
    Nov 2009
    USA
    Make sure that lic file is in the same directory as the carprog executable file...
    It is on the cd that came with the device... Just copy and paste...
    Take care...
    Jul 2009
    here there
    in the same directory as carprog executable file it must be a .lib file. that is the database of your carprog interface.
    Mar 2012
    PHX
    Quote Originally Posted by tokentalonguy View Post
    Cheers Darryl
    "im pretty sure that my unit is a clone also."
    it either is or it isn't why play stupid games and waste everyones time...
    20Mhz Intel? 80386 CPU - VGA Graphics - 2 MB RAM (16 MB Capacity) - 60MB HDD - SCO? XENIX?
    Jul 2013
    Quote Originally Posted by digitaltech View Post
    First off im not trying to waste anyones time. i only think it is a clone but with a little research i found out the unit is a clone.
    Jul 2013
    Quote Originally Posted by RCS View Post
    Take care...
    i got that lib file in its directory now. It reads the device, then verifys ok, but when i hit the find crash data but i get a message "crash not found"
    Nov 2009
    USA
    Also use only software carprog.exe from the cd and do not download new versions from Internet...
    After you succed with initial version that came with the device than you can try other versions...
    Sent from my iPad using Tapatalk HD
    Jun 2010
    far far away
    hi i have vauxall signum 2004 i need pin of this car i got eepro read from ecu edc16 , someone can calculate it from this dump . thanks
    Jun 2010
    far far away
    Post vauxall signum 2004 i need pin
    hi i have vauxall signum 2004 i need pin of this car i got eepro read from ecu edc16 , someone can calculate it from this dump . thanks vauxhall ecu eprom edc16 19dt 2004.rar
    how can run Carprog soft without interface?
  11. #11
    carradio2001's Avatar
    Nov 2009
    France
    Quote Originally Posted by Djtroliz View Post
    9237.
    Carradio2001.
  12. #12
    Jun 2010
    far far away
    thank u very much
