Results 1 to 9 of 9
    Jun 2013
    Default skybox f5 Random scrambled channels
    Just updated latest aj channel list and ccam supplied by operator. I'm now getting randomly scrambled channels. E.g.I have all slysports, but no sly sports news.
    Moving up and down through channels using large arrows also occ. Causes scrambling.
    Any ideas ?
    Cheers....
    Jun 2013
    I had similar problems, see my posts
    Jun 2013
    Had a look at your posts. Did you get a solution to this problem though ?
    Cheers....
    Oct 2008
    I'm getting this too...
    Channels work, then i can cycle right through music favs, go to a $ chan and it will say scrambled. sometimes even says invalid program!
    If i reboot box they all work again... i'm starting to get really pee'd off!!
    Anyone know the most stable firmware??
    I dont care about youtube etc.
    Hadron's Avatar
    Nov 2012
    E. London
    I have had this problem for ages on different boxes (S9, S10, S11, X3) with all kinds of different firmware. It only seems to happen after I have flicked through some FTA channels & then back to a $ channel.
    Apart from switching the box off & on again, I haven't found any other way of getting the $ channels to unscramble again.
    Jun 2013
    diode fix sorted 90% of my problem, think rest of no signal is down to dish, (builders been working close to it and no dowt they moved by mistake) from what I've gone through so far, bt sport very poor signal on mine, lines through picture and freezing, Liverpool tv the same, I think I must be dish out by a bit, will update once I get mate with signal tester to check for me
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by mmyoung View Post
    There has been a lot of changes recently to channel frequencies such as Sky Sports News HD ,Discovery HD, More4 HD etc There is now a new channel list to download from Ajs which will fix this problem, Andy.
    Jun 2013
    hi andy, tried aj's and sky list still same problem, must be dish, will get it checked
    Jun 2013
    after I upload list is it worth doing a rescan, or am I just duplicating things
