Results 1 to 8 of 8
    Default peugeot 307 fap-egt
    please need help with dpf egr off
    the car is peugeot 307 EDC16C3 ecu 0281011234
    thank you very much in advance.
    regards
    Someone have tested solution because fan work after stop the car and ignition off ?
    TEst and report. Pass pm
  4. The Following User Says Thank You to pelot For This Useful Post:
    carbyvw (25th July, 2013)
    Dec 2012
    hi,I need help dpf off in peugeot 2.0 hdi
    Quote Originally Posted by arcar View Post
    ecusafe and volta do it well
    Oct 2012
    Attached ecusafe done file.
  8. The Following User Says Thank You to 786mo For This Useful Post:
    arcar (1st August, 2013)
  9. #7
    Romania
    Default FAP peugeot 307 EDC16C3 ecu 0281011234
    Hello.Can help me somebody to remove properly the fap from peugeot 307 EDC16C3 ecu 0281011234.
    Thanks for helping.
  10. #8
    digi men's Avatar
    Nov 2013
    EU
    here is your dpf off
    pass in pm
  11. The Following User Says Thank You to digi men For This Useful Post:
    illestibor (11th January, 2014)
