Results 1 to 4 of 4
    Mar 2013
    Wink Vito windscreen washer pump control module location ?
    Car :Vito 1998
    The customer forced the washer pump (the liquid in the washer tank was frozen ) until the pump died.
    Simptoms:
    -when push the washer pump button there is no liquid spill ,just a small buzz in the pump AND wipers don t work 3 times as it should
    -if disconect the washer pump and push the washer pump button , the wipers work 3 times and there is voltage to washer pump (checked with test lamp ,about half amp load )
    -the wipers work normal if used separatly
    Checked :
    -washer pump ( replaced with a new one ) but the simptoms are the same
    -ground to washer pump ok
    -scoped the voltage to washer pump ,look good without pump (about 12 volts pulses ) ,look bad with the pump (about 2 volts pulses )
    My guess is that the control module has a current sensor ( a resistor ? ) which could be fried and for that reason current protection act too early.
    Question is where to look for that module (A11 ? ) ?
    Meat-Head's Avatar
    Nah, just bang a relay across where the pump should be, tap power off glow worm relsy, jobs a carrot
    99 red baloons chance the switch has got hot, diftened contacts and nil poi
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    TR0UBLESH00TER (30th July, 2013)
    Mar 2013
    Meaty you are right , it s a Merc not a space shuttle , it s all electric ,not electronic .Until I managed to install WIS customer solved the problem , 8 hours work for a few oxidated switches near steering column
    Meat-Head's Avatar
    Eh 8 hours to do what?
    remember french or german or emerican two. Rules apply
    dead simple or unbealable complex
    opposite to what you expect, but makes perfect sense when explained
    example
    french cars wipers were live all the time, (parking) opposite to what you expect but makes sense when explsined stops wipers freezing to window overnight burning motor out next morning, because it froze parked
