How to fix missing channels for the newbies
  • P&D
    • May 2010
    • 2686
    If some of your channels say scrambled after a frequency change's the easiest way to fix them.....
    If you don't know how to update the box with Aj's or Sattv5 channel list (which are the best i have found so far ) via usb then follow the info below.....
    You need to find out which transponder the channel has moved to..... Plz see link below provided by cactikid thx mate
    or i'm sure others member will update us when this happens....
    For example.....
    E**N HD has just changed transponder from 12304-H to 11585-H so i guess your channel is scrambled ....
    This is the easy part ...
    Lets use the example above .......
    Press menu
    goto TP list.....(if you cannot enter your TP list because it's not high-lighted plz see post 4# below) Big thx to DW190
    Once in the TP list scroll up or down till you find 11585 (Or the transponder channel you want to scan)
    press the blue button (search)
    yes (press ok)
    Let the search run takes a few seconds....
    Exit Exit ...
    Bob's your uncle channel back....
    You will need to this with each channel thats missing......
    hope this helps
  • cactikid
    • Sep 2008
    • 12017
    bookmark this to pc or lappy its the bible for sat =when changes happen and that is very often.
    Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingOfSat
    • P&D
      • May 2010
      • 2686
      Go into the menu....sat list.....press ok.....you will see a green tick top left.... exit.......TP list back
      http://www.digital-kaos.co.uk/forums...0/#post2041582 thx to DW190
      • P&D
        • May 2010
        • 2686
        Originally posted by gg1a
        what does it mean when says failed when seaching transponders as im missing channels that i should get from client
        Helps to know what channels
        • DW190
          • May 2012
          • 1263
          Originally posted by MonsterSquad
          Is there anyway of storing the changed frequency channel to your current channel list. I've found the channel through the search but I've been trying to move it with no joy whatsoever
          Sent from my GT-I9305 using Tapatalk 4 Beta
          Of course there is a way, that's how we get the channel lists updated by the likes of AJ who spends quite a lot of time keeping it up to date. (Not easy if your working full time as I do).
          When you are in the All List (OK, Red Button, All) select any channel then Menu, Edit Channels, Favorite edit. You then press the Fav Button to selct the Fav you wish to add channels to and go through the list pressing OK to add channels. When done exit making sure you select Yes when asked to save.
          If you give yourself about four or five hours you could start from scratch and create a full channel list that suits or spend a short time ammending such as AJ's to suit as I did.
          If you really want to make it easy you can get an E2 Linux box and add Auto Bouquetes which sorts them all straight from the Sat at the press of a button or will do it its self if you set the schedule.
          • Hadron
            • Nov 2012
            • 2102
            It depends how quickly you want your channel back.
            That's a great site, but is often very slow to update channel changes. Can take days sometimes.
            If you think a channel may have changed frequency, & you want it back quick, you could do a complete sat scan, find where the channel has moved to, re-install the channel list you were using, then scan the TP that the channel moved to.
            ...Then let everyone on DK know where it is.
            • DW190
              • May 2012
              • 1263
              Originally posted by mark9111
              when ive rescanned for espn it comes back on but when i want to go back to that channel at a later stage i have to rescan it again
              Once you have scanned the TP and got the channel it will be in the ALL list. Make a note of thehen channel number.
              When any channel, press OK, Red Button and OK on ALL then go to the channel number you made a note of.
              • Hadron
                • Nov 2012
                • 2102
                If you want to replace your current (non-working) ESPN HD with the working one, and put it back into the "Sports" favourite, then I noted down what I had to do as I was doing it. It looks long winded, but when you have done it once, it's quite straightforward.
                The channel numbers are based on AJ's list (dated 25-7-13). There are 2 ESPN HD channels on 11585H. the one with SID 3841 is the one listed on KOS.
                Press Menu button -> Installation -> TP list.
                (If TP list is greyed out, select "satellite list". Press OK to place tick next to line of the satellite you want to scan. Press Exit).
                Select TP to scan.
                Press OK. Press OK again to confirm.
                When search has finished, press OK to confirm ("yes" Search End).
                Press Exit twice to get back to Menu.
                Select "Edit Channel" Menu.
                Select "Channel Edit".
                Scroll to old $ESPN HD channel (0157).
                Press OK to select it.
                Press RIGHT triangle on remote, then scroll down to X (delete).
                Press OK to delete channel.
                Scroll down list to new $ESPN HD channel (0595).
                Press RIGHT triangle on remote to highlight "MOVE".
                Press OK.
                Use PG+ & PG- or UP & DOWN triangles on remote to move channel back to position 0157.
                Press OK.
                Press Exit.
                Press OK to confirm changes.
                Select "Favorites Edit".
                Press "Fav" button on remote.
                Scroll to "Sports".
                Press OK.
                Scroll to 0157 $ESPN HD on left hand "All Satellite" list.
                Press OK to tick it.
                Press RIGHT triangle on remote to select + (add).
                Press OK. A heart will appear next to channel & it will be added to "Sports" list.
                Press Exit.
                Press OK to confirm change.
                btw...this was for an X3 box which, I think, is the same for most other boxes, except maybe the S9,10, & 11.
                • digicon
                  • 8261
                  Ok Made this a sticky and removed Posts that are not relevant.
                  Dont forget no need to post Thanks use the Buttons bottom right 'Like' bottom left 'Thanks' to the Original Posters
                  • tom9999
                    • May 2014
                    If you've followed the suggestions above and are still missing channels, try the following.
                    So very quickly, I had carried out all of the suggestions and procedures from the thread (TP List search, downloaded the latest AJ lists etc) and I was still missing a number of channels. I was fairly sure it was not an issue covered above so I tried reformatting my USB (saving all of the files off it first). I plugged it back into the box and for some reason (I probably did something wrong!) it wasn't being recognised by my box. So I copied the files onto a different USB, upgraded the relevant ones and the missing channels were now displaying.
                    Seems obvious now but try upgrading with a new USB
                    • bernie631
                      • Jul 2014
                      • 9
                      I wish I had seen your post before going down another route which has resulted in having no channels
                      • katoy
                        • Jun 2014
                        • 2
                        I have re-done my f5s box several times and I get all free to air channels but my $ channels just keep saying scrambled don't know what to do ive e-mailed the guy who sold me the box but aint heard a thing back please help me get my channels back
                        • digicon
                          • 8261
                          @katoy,
                          I am afraid you will receive no help in trying to get any Scrambled channels back its clearly written in the Forum Rules.
                          All i will say is Try Google
                          • Fejinwales
                            • Oct 2013
                            • 14
                            Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingO**at
                            This link does not work I'm afraid. Wether I am on my VPN or not. I need the listing to get PBS back.
                            Life is not measured by the number of breaths we take, but by the number of moments that take our breath away.
                            • digicon
                              • 8261
                              #15
                              Try This:
                              http://en.kingo.f.s.at.net/pos-28.2E.php
                              Remove the dots before the F and after the s
