Page 1 of 3 123 LastLast
Results 1 to 15 of 32
    P&D's Avatar
    May 2010
    Default How to fix missing channels for the newbies
    If some of your channels say scrambled after a frequency change's the easiest way to fix them.....
    If you don't know how to update the box with Aj's or Sattv5 channel list (which are the best i have found so far ) via usb then follow the info below.....
    You need to find out which transponder the channel has moved to..... Plz see link below provided by cactikid thx mate
    or i'm sure others member will update us when this happens....
    For example.....
    E**N HD has just changed transponder from 12304-H to 11585-H so i guess your channel is scrambled ....
    This is the easy part ...
    Lets use the example above .......
    Press menu
    goto TP list.....(if you cannot enter your TP list because it's not high-lighted plz see post 4# below) Big thx to DW190
    Once in the TP list scroll up or down till you find 11585 (Or the transponder channel you want to scan)
    press the blue button (search)
    yes (press ok)
    Let the search run takes a few seconds....
    Exit Exit ...
    Bob's your uncle channel back....
    You will need to this with each channel thats missing......
    hope this helps
  2. The Following 60 Users Say Thank You to P&D For This Useful Post:
    Abdul83 (11th March, 2014), amjadhussain (10th August, 2013), andy91 (29th July, 2013), baadboy (8th January, 2015), bewal1 (2nd August, 2013), bigalex (21st October, 2013), bighank224 (7th October, 2013), captainglassback (11th September, 2013), chris31560 (15th February, 2017), chubbs9 (3rd August, 2013), cleggy53 (25th January, 2014), craigcaroletomliam (22nd October, 2013), deano16 (1st August, 2013), Dick Dastardley (10th May, 2014), djotay (9th August, 2014), eddiepara (13th March, 2014), fawada123 (25th October, 2013), gavwally (24th December, 2013), goldberg (10th August, 2013), jackjay1 (12th March, 2014), jackthelad662000 (29th January, 2014), janeye (13th November, 2013), jc69817 (17th March, 2014), leeant (6th August, 2013), maccas69 (16th October, 2013), markprice1984 (5th October, 2013), mguru (1st December, 2013), minelab (3rd January, 2016), mininfcc (20th August, 2013), Mysteriousguy (30th July, 2013), nicknak19 (30th July, 2013), Pezza321 (29th March, 2014), philfrommancs (6th August, 2014), plutox2 (7th October, 2013), protek (21st December, 2013), psychophil (30th July, 2013), RegVardy (2nd October, 2013), resonance (24th October, 2013), Rox13 (10th October, 2013), royal31 (24th October, 2013), samcanady (27th March, 2014), Saucy7 (2nd August, 2013), scooterboi150 (5th August, 2013), scotty1965 (30th July, 2013), seatonwills (31st July, 2013), SheWolf (27th March, 2016), silverlec (11th October, 2015), SLICK181818 (9th January, 2014), sohaillf (2nd July, 2015), Spartan50 (11th November, 2013), Striper Man (16th October, 2013), surapan (6th July, 2014), tailorvti (26th December, 2013), thanidar (4th August, 2013), votator (22nd August, 2013), wally6529 (5th October, 2013), willywizard (30th July, 2013), winmck80 (23rd February, 2014)
  3. #2
    Sep 2008
    bookmark this to pc or lappy its the bible for sat =when changes happen and that is very often.
    Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingOfSat
  4. The Following 23 Users Say Thank You to cactikid For This Useful Post:
    Abdul83 (11th March, 2014), amjadhussain (10th August, 2013), baadboy (8th January, 2015), badboy1965 (23rd October, 2013), bigalex (21st October, 2013), bys561999 (25th August, 2013), cleggy53 (25th January, 2014), djotay (9th August, 2014), goldberg (10th August, 2013), joe516 (29th September, 2014), leeant (30th July, 2013), minelab (3rd January, 2016), mininfcc (20th August, 2013), Mysteriousguy (30th July, 2013), NuttyButty (28th October, 2017), Pezza321 (29th March, 2014), ppady (20th January, 2014), royal31 (24th October, 2013), samcanady (27th March, 2014), sparkie1234 (12th April, 2014), thanidar (4th August, 2013), wally6529 (5th October, 2013)
  5. #3
    P&D's Avatar
    May 2010
    Go into the menu....sat list.....press ok.....you will see a green tick top left.... exit.......TP list back
    http://www.digital-kaos.co.uk/forums...0/#post2041582 thx to DW190
  6. The Following 7 Users Say Thank You to P&D For This Useful Post:
    Abdul83 (11th March, 2014), deano16 (1st August, 2013), minelab (3rd January, 2016), randersod (6th August, 2013), scooterboi150 (5th August, 2013), scotty1965 (30th July, 2013), walf (30th July, 2013)
  7. #4
    P&D's Avatar
    May 2010
    Quote Originally Posted by gg1a View Post
    what does it mean when says failed when seaching transponders as im missing channels that i should get from client
    Helps to know what channels
  8. The Following User Says Thank You to P&D For This Useful Post:
    024U (12th October, 2013)
  9. #5
    May 2012
    Quote Originally Posted by MonsterSquad View Post
    Is there anyway of storing the changed frequency channel to your current channel list. I've found the channel through the search but I've been trying to move it with no joy whatsoever
    Sent from my GT-I9305 using Tapatalk 4 Beta
    Of course there is a way, that's how we get the channel lists updated by the likes of AJ who spends quite a lot of time keeping it up to date. (Not easy if your working full time as I do).
    When you are in the All List (OK, Red Button, All) select any channel then Menu, Edit Channels, Favorite edit. You then press the Fav Button to selct the Fav you wish to add channels to and go through the list pressing OK to add channels. When done exit making sure you select Yes when asked to save.
    If you give yourself about four or five hours you could start from scratch and create a full channel list that suits or spend a short time ammending such as AJ's to suit as I did.
    If you really want to make it easy you can get an E2 Linux box and add Auto Bouquetes which sorts them all straight from the Sat at the press of a button or will do it its self if you set the schedule.
  10. The Following 2 Users Say Thank You to DW190 For This Useful Post:
    MonsterSquad (30th July, 2013), SpikeyMikey (11th December, 2013)
  11. #6
    Hadron's Avatar
    Nov 2012
    E. London
    Quote Originally Posted by cactikid View Post
    It depends how quickly you want your channel back.
    That's a great site, but is often very slow to update channel changes. Can take days sometimes.
    If you think a channel may have changed frequency, & you want it back quick, you could do a complete sat scan, find where the channel has moved to, re-install the channel list you were using, then scan the TP that the channel moved to.
    ...Then let everyone on DK know where it is.
  12. The Following 2 Users Say Thank You to Hadron For This Useful Post:
  13. #7
    May 2012
    Quote Originally Posted by mark9111 View Post
    when ive rescanned for espn it comes back on but when i want to go back to that channel at a later stage i have to rescan it again
    Once you have scanned the TP and got the channel it will be in the ALL list. Make a note of thehen channel number.
    When any channel, press OK, Red Button and OK on ALL then go to the channel number you made a note of.
  14. The Following 3 Users Say Thank You to DW190 For This Useful Post:
    bys561999 (25th August, 2013), edoardo (13th December, 2013), wonkeenose (24th November, 2013)
  15. #8
    Hadron's Avatar
    Nov 2012
    E. London
    If you want to replace your current (non-working) ESPN HD with the working one, and put it back into the "Sports" favourite, then I noted down what I had to do as I was doing it. It looks long winded, but when you have done it once, it's quite straightforward.
    The channel numbers are based on AJ's list (dated 25-7-13). There are 2 ESPN HD channels on 11585H. the one with SID 3841 is the one listed on KOS.
    Press Menu button -> Installation -> TP list.
    (If TP list is greyed out, select "satellite list". Press OK to place tick next to line of the satellite you want to scan. Press Exit).
    Select TP to scan.
    Press OK. Press OK again to confirm.
    When search has finished, press OK to confirm ("yes" Search End).
    Press Exit twice to get back to Menu.
    Select "Edit Channel" Menu.
    Select "Channel Edit".
    Scroll to old $ESPN HD channel (0157).
    Press OK to select it.
    Press RIGHT triangle on remote, then scroll down to X (delete).
    Press OK to delete channel.
    Scroll down list to new $ESPN HD channel (0595).
    Press RIGHT triangle on remote to highlight "MOVE".
    Press OK.
    Use PG+ & PG- or UP & DOWN triangles on remote to move channel back to position 0157.
    Press OK.
    Press Exit.
    Press OK to confirm changes.
    Select "Favorites Edit".
    Press "Fav" button on remote.
    Scroll to "Sports".
    Press OK.
    Scroll to 0157 $ESPN HD on left hand "All Satellite" list.
    Press OK to tick it.
    Press RIGHT triangle on remote to select + (add).
    Press OK. A heart will appear next to channel & it will be added to "Sports" list.
    Press Exit.
    Press OK to confirm change.
    btw...this was for an X3 box which, I think, is the same for most other boxes, except maybe the S9,10, & 11.
  16. The Following 15 Users Say Thank You to Hadron For This Useful Post:
    accies (5th August, 2013), bys561999 (25th August, 2013), dan602 (7th June, 2014), davef1956 (18th March, 2014), leeant (12th October, 2013), mixersmate (6th January, 2014), P&D (31st July, 2013), philfrommancs (6th August, 2014), plonky (18th October, 2013), RegVardy (2nd October, 2013), rentcollector (25th October, 2013), SheWolf (14th August, 2014), sohaillf (2nd July, 2015), thanidar (4th August, 2013), votator (22nd August, 2013)
  17. #9
    digicon's Avatar
    Jul 2009
    Ok Made this a sticky and removed Posts that are not relevant.
    Dont forget no need to post Thanks use the Buttons bottom right 'Like' bottom left 'Thanks' to the Original Posters
  18. The Following 3 Users Say Thank You to digicon For This Useful Post:
    Hadron (2nd August, 2013), Springer100 (2nd August, 2013)
  19. #10
    May 2014
    If you've followed the suggestions above and are still missing channels, try the following.
    So very quickly, I had carried out all of the suggestions and procedures from the thread (TP List search, downloaded the latest AJ lists etc) and I was still missing a number of channels. I was fairly sure it was not an issue covered above so I tried reformatting my USB (saving all of the files off it first). I plugged it back into the box and for some reason (I probably did something wrong!) it wasn't being recognised by my box. So I copied the files onto a different USB, upgraded the relevant ones and the missing channels were now displaying.
    Seems obvious now but try upgrading with a new USB
  20. #11
    Jul 2014
    I wish I had seen your post before going down another route which has resulted in having no channels
  21. #12
    Jun 2014
    I have re-done my f5s box several times and I get all free to air channels but my $ channels just keep saying scrambled don't know what to do ive e-mailed the guy who sold me the box but aint heard a thing back please help me get my channels back
  22. #13
    digicon's Avatar
    Jul 2009
    @katoy,
    I am afraid you will receive no help in trying to get any Scrambled channels back its clearly written in the Forum Rules.
    All i will say is Try Google
  23. #14
    Oct 2013
    Astra 1N / Astra 2A / Astra 2D / Astra 2F / Eutelsat 28A / Eutelsat 28B (28.2?E) - All transmissions - frequencies - KingO**at
    This link does not work I'm afraid. Wether I am on my VPN or not. I need the listing to get PBS back.
    Life is not measured by the number of breaths we take, but by the number of moments that take our breath away.
  24. #15
    digicon's Avatar
    Jul 2009
    Quote Originally Posted by Fejinwales View Post
    Try This:
    http://en.kingo.f.s.at.net/pos-28.2E.php
    Remove the dots before the F and after the s
  25. The Following User Says Thank You to digicon For This Useful Post:
    fraggit (15th April, 2015)
