Results 1 to 15 of 30
    Default Audi RB4 dash 8E0920930J problem after battery replacement
    Does somebody has experience with these problem?
    Client replace battery and no needles, light on dash.
    VCDS has read DTC 00576 - terminal 15 27-00 Implausible signal
    I checked power supply on pin 2 and 3 of green connector everything is OK but problem still present.
    Thanks!
    pepi's Avatar
    Try to write another dump on 24c08 with the same brand just to check if needles will move up. After you will cary out programming.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Another dump in RB4 crypto? )))
    Just try and cry after
  4. The Following 4 Users Say Thank You to lupu_sandu For This Useful Post:
    amigokola (17th November, 2016), gecibogar (13th November, 2021), tihiuvek (1st August, 2013), yugo45 (18th November, 2016)
    Bosna
    Read eeprom and try to compare with eeprom from another dash, same part number, maybe you can see something wrong in your dump.
    pepi's Avatar
    Quote Originally Posted by lupu_sandu View Post
    No need to cry if you have AVDI or DEJAVU. I do it without problems always.
    Dec 2012
    Hello!
    I know two other cases with exactly the same problem.
    One of them is an A4 MY2002 with the 8E0920930J and the other one is an A4 MY2003 with 8E0920930R cluster.
    The problem is that the cluster makes some kind of reset and its coding and all the Adaptation channels return to 0 value.
    All you have to do is set the coding and all the Adaptation channels back to the original value and you should solve all the issues you mentioned.
    I uploaded a map of the adaptation channels of another instrument cluster that you can use to set some values.
    Of course that in some channels you have to set the values based on the car specs!
    10 adpmap-17-8E0-920-930-T.txt
    Now you probably will get an annoying issue that I myself still don't understand and i am also looking for a solution with no results till now, it is the fuel range in DIS that starts to increase its value all the time you run the car and stops at 2000Kms (I suppose it is the maximum range possible in the DIS.
    This is even more strange since the fuel gauge is showing the correct level in the tank and even in Vag-Com is showing the correct liters.
    If anyone know how to solve the fuel range issue, any help would be great!
  8. The Following 2 Users Say Thank You to nirv For This Useful Post:
    amigokola (17th November, 2016), sagie1zn (20th June, 2019)
  9. #7
    Feb 2015
    Hello
    Your problem is inside 24C08 ....... your file ?
    Inviato dal mio SM-T805 utilizzando Tapatalk
  10. #8
    Dec 2012
    Hello!
    Here is the dump file of one of the the clusters having the fuel range bug:
    https://0a7sgh.s.cld.pt
    This one was taken from an Audi A4 MY2002
    I know another case from an Audi A4 MY2003, but I can not find the dump file.
    It would be great to solve this issue!
  11. #9
    Dec 2012
    Here it is the other dump file, with the same fuel range bug.
    This is a 8E0 920 930 R cluster
    https://rx7o6s.s.cld.pt
  12. #10
    Dec 2012
    I am still searching for a solution for the referred fuel range problem.
    It is not an easy information to find.
    Does anyone have an idea related to this problem?
  13. #11
    Sep 2015
    Germany
  14. The Following User Says Thank You to Nadisat For This Useful Post:
    nirv (22nd March, 2017)
  15. #12
    Dec 2012
    Quote Originally Posted by Nadisat View Post
    Thank you for your help, but the reported problem is not directly related to the one described here.
    I am almost shore that the fuel range problem is related to a missing calibration of the fuel level.
    I just don't know how to do it.
  16. #13
    koln, germany
    when yoiu set calibration as 4WD when it isn't you get that problem check coding datas
  17. The Following User Says Thank You to isma123 For This Useful Post:
  18. #14
    Dec 2012
    Quote Originally Posted by isma123 View Post
    That is correct, when you code the cluster to 4WD in a 2WD car, the fuel gauge will not display the correct level on the tank.
    But that is not the problem I am experiencing since the cluster is coded to 2WD in a 2WD car and the fuel gauge is showing the correct fuel level on the tank.
    Even in the VCDS Measuring Blocks, the liters are shown correctly.
    I believe that the problem is related with this Adaptation channels:
    Channel 030 - Tank Characteristic (Fuel Level Sensor 1)
    This is a parallel shift of the tank characteristic.
    Channel 032 - Tank Characteristic (Not detactable Tank Volume)
    The tank volume which is not recordable by the fuel gauge sender(s).
    Channel 033 - Tank Characteristic (Full Calibration)
    Non-parallel shift of the tank characterictic above a readout of 1/2.
    To start the adaptation enter '65535' as new value.
    Channel 034 - Tank Characteristic (Additional Functions)
    Full Correction Sensor 1
    1 - active / 0 - not active
    I am almost shore that the solution for the fuel range issue can be solved with this Adaptation channels, I just don't know the procedure.
    I will try to make the procedure described on the Channel 030 when the tank is full and see what happens...
  19. #15
    Jan 2016
    Someone knows how to solve this 2000km issue ?? I got car after someone tried to start it with week battery.
    Did all adaptations and dash is working but only 2000km problem left.
    Thank's in advance.
