    Jun 2009
    Default fiat strada multijet 1.3 75hp sw34545168 mjd6f3hw03r dias fiat 51803864
    code omo= 6f3.s147
    the cars turbo starts at 2800rpm and i need the turbo to start at 1500rpm .
    the car has no good performance and the fiat dealer does not have a update for this .
    i need the car to be tunned to have better performance and i prefer turbo to start at 1500rpm.
    here is the file
    thanks a lot those that will helporiginal.rar
    carmageddon's Avatar
    Italy
    friend, with diesel motor the turbo pressure is dependent from iniection quantity!
    all 1.3 mjet need diesel fuel from 1300 rpm, new value for torque request/limit and right lambda/advance settings
    with right mod 1.3 mjet start his performance from 1300 rpm and run strong after 5000 rpm without problem.
    Jun 2009
    i am not expert in tunning only in immos.
    Does anyone has a ready tunning for this car? its a common problem for this 1.3multijet
    actually turbo comes from exhaust gases, which are produced by burning fuel, but if you burn more fuel, you dont have enough air to make proper combustion...you get caughet in a permamanent circle...
    the only way out is smoking
    Jun 2009
    someone to change the maps so the car to go better performance from 1500 to 2800rpm .after the 2800 rpm that works the turbo the car is ok for the customer
    Jun 2009
    a little help
