No torque mate..that is IQ x air temp map, 2 of them
try replacing your temp sensor..
Hi everybody, I have a Siemens PPD Passat TDI 103kw with hot start problems.
Car starts perfectly when cold.
Car starts very very bad when hot (90deg); more or less 10-15seconds for starting.
Car starts perfectly when hot (90deg) if I simply disconnect water temperature sensor.
ecu:03G906 018CD PPD1.5 siemens
car:Passat 2.0tdi 103kW
I readed file at OBDII.
I need modification map torque start.Please file with chk.
Thanks in advance.
BR
Kusasusa
I have made some mod for you. I have raised the IQ regarding the high temp. in those two maps, CKS its OK.
But like omini tould, you should check the temp sensor with VAG-COM. You should also check the camshat-s timing, I have see some Passat-s to have similar problem becouse of bad timing.
BR and post resoults.
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
rossoelab (17th October, 2013)
Your PM its full, release some space to get the password.
__________________
If You Like My Post
I will test and report.
My PM realesed.
Thanks a lot.
Hi,,
problem in pf bad timing.
Br
Kusasusa
Artilect (9th August, 2013)
Thanks for feedback, good to see you have solved your problem.
BR
__________________
If You Like My Post
I have the same problem hot start
send pass please
Here you go. Try and respond, but check the timing first.
BR
__________________
If You Like My Post
