Hi all, ok so ive successfully installed HB from the letterbomb hack....but im now having trouble with the cios installer onwards. Can someone run through an updated method from where I am please...I want to use usb loader gx...thanks in advance
Welcome to DK.
You need to download sysCheck19 and add it to the SD card and run it from Homebrew then post a full report as instructed in that link so I can see which IOS's you have installed.
Keith
2010 Golf GTD (170)
ukconvict (1st August, 2013)
Hi Keith, thanks for replying...I will have the syscheck report for you later this evening...if I can get this working ill be very grateful
Hi, right just tried running the syscheck and it went through until the end when it came up with a big red cross and "failed to find TMD for IOS36" ???
It shouldn't say failed to find anything it only check which IOS's are installed.
The confusing bit is IOS36 can be connected to IOS236. Download ios 36 v3608 and make sure you add it to the wad folder on the SD card and install it with Multi-Mod-Manager (MMM) v13.4 from Homebrew. Run MMM and move down to WAD Manager and press 'A'. I don't know how many wads you have in that folder but scroll down until you see IOS36 3608 listed and press the small + button to put a green tick next to it the press 'A'. The next screen will show you the same IOS36 3608 just press 'A' to install it, watch for the Installed OK message afterwards. If it doesn't install just go back and try it again.
If that does cure the error then download IOS236-v5-Mod and add that to the SD card IOS36-64-v3351.wad must be on the root of the SD card else it won't work. Start Homebrew and install that you will see it listed as IOS236 Installer v5 Mod.
Then run sysCheck and post a report.
Keith
2010 Golf GTD (170)
