immo is in the cem module.:-)
Need to clone my ECU to a used one.
But were is immo located?
I have a 93c56 as i clone, but only 1kb and it's not there.
I have flash 29F400 as i clone but car don't start...
Please help!
In both cem and ecu
I have change to a used one but car don't start
Which ecu is it exactly?
Denso
09497544a
HE.2
ok, what do you mean with
the second ecu has no 93c56?
I seem to remember that Denso ECU for Transmission,check & make sure.
This is the ecu for engien. (Ecm)
When i read 93c56 i only got 1kb file?
Yes the used ecu has same eeprom 93c56
Have read eeprom with carprog and wilem but only 1kb
Were is immo stored in ecu?
i had one a volvo S80 biturbo and ecu was bosch, next to the transimsion one.
you ll have to replace ecu, CEm and key. CEm has the middle part as of a rack..it slides out
hi
maybe help you
Volvo S40 2004-2009, V50 2004-2009, C30 CEM repair and synchronization with SID803 motor ECU utility.
How immobilizer works on Volvo S40 2004-2009, V50 2004-2009, C30 :
Immobilizer data (immo) on these cars are stored in the Central electric module (CEM) located in driver compartment fuse box.
CEM receive transponder key signal from immobilizer coil and if key data is equal to the vehicle.
Send synchronization signal to motor ECU.
If transponder key is stored in CEM and synchronization data CEM-ECU is correct,
the CEM permits the engine to start.
Motor ECU also is synchronized with ABS computer ID.
For the SID803 ECU replacement, you must also read ABS ID (you can read ABS ID with Launch X431, Diagun or other tool by OBDII) and write it to the SID803.
How to use this program:
Most common problems on these cars is that the synchronization is lost between the CEM-ECU after a battery discharge.
In motor ECU fault code "No communication with immobilizer" is active and car does not start.
Remove CEM and read with CarProg A10 adapter processor EEPROM - see picture for details.
Also remove SID803 and read 95320 EEPROM.
Open both files and write synchro data from CEM to SID803.
Also write ABS serial ID. Save the SID803 modified file and write it to SID803.
If you need to program second-hand motor ECU - procedures are the same.
Volvo S40 2004-2009, V50 2004-2009, C30 CEM repair and synchronization with SID803 motor ECU utillity. UPDATED!!! V2.4 - Small soft
regards
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
foxdata (26th April, 2017)
Thanks friends but this is not the answer om my post.
The program don't help me here on tis problem.
The ecu is a Denso.
I have read flash and eeprom and clone to used ecu, but car don't start...
The car is 5 gear so i don't have a ecu for auto,gear in the black plastic box were ecu is stored.
Please need more tips!
Thanks all!
searched everywhere,,and found no such volvo with Denso ecu...
tell me exact model, engine hp etc..
Volvo S80 2000 2,4i 170hp
B5254S
YV1TS61F2Y1130211
5gear
i still think ecu should be bosch Me7, under the hood, on passenger side next to auxiliary belts in a black box.!
Did the same successfully on my b5244s2 (140hp) and flashed the immo to a b5244s (170hp) ECU. Only copied 93c56 using carprog. But I remember something like 256 Byte...
I search for the immo file, so maybe you could compare... (PM with mail?)
