Results 1 to 5 of 5
    Default Help Updating Channels
    Just wanted to know the best and easiest way to update the channels on the Dm800se?
    This is how I do it at the moment......Basically I have an freshly scanned channel list from the box and have this opened in the dreambox edit now i also open another dreambox edit (2 programs opened up) then find the modified channel and transfer it over to the channel list? I know it sounds a bit daft but this is what im use to doing?
    there must be a better way of doing this guys or you may even be able to change the freqency numbers in dreambox edit without doing a scan all the time?
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by toe471 View Post
    Have you tried a channel list like Catseyes? Regular updated and if you need to update the odd channel do it with the remote control, Andy.
    digicon's Avatar
    If your just using 28.2? east then this is right up your street: http://www.digital-kaos.co.uk/forums...e-plug-296869/
    Yeah its 28.2E list and im also using SGT List, I mite have a bash at using the Autobouguets plug-in, Im sure you can download it through the TSpanel section?
    Aug 2010
    East Midlands
    You can it also will put your regional TV but I like the layout of Catseyes bouquets, you can find it in downloads or in the bouquet section in the sat section.http://www.digital-kaos.co.uk/forums...7/index22.html Andy
