DOESNT ESPN EXIST NOW THEN AS ESPN HAS ALWAYS WORKED FOR ME
Claire refrain from using caps in forum terms that's a form of shouting. If you read a few of the posts you would read that BT are taking over Espn and recently there are a lot of frequency changes going on in the sat scene hence new channel lists. Take some time to read through a few posts before posting as the answers are staring you in the faceWe also have a search button which helps. This saves members repeating the same things day in day out, Andy.
Hi This list is good in the sense all channels are how you are used to them, but is it possible to delete the blank channels, so you can use the up arrow, However i am conscious of the fact if i do this i will have to do it every update. Also ESPN HD does not work but all my other sports do. thanks for your info
hi mate, i am new and your advice is spot on, i too asked the question about espn, is it true bt sports have took them over? if this is true its not really a great channel other than a rebranded one. im finding my way around channel lists and updates now, and have just done sattv sky list which is v good.
Hello all. Does this channel list have all the channels in SD is well?
where can i get another one from ?
Yes and follows the same numbering as a sky box and the sky tv guide website
Sky Guide TV Listings - Sky
Have a look at this post mate it might help you if you want to add or delete channels,
http://www.digital-kaos.co.uk/forums...ewbies-356919/ Andy.
ive been onto my supplier and bt sports is supported but for some reason on my box its scrambled anybody got any ideas ????
hi av you got the latest channel list on you box ? what does the frequency say on yours it should be 11585.00H/29500
Thanks will try later but being a newbie if i get stuck i'll come back not to pour scorn but to praise with the hope that as you put in the hard work saving me doing it that others may help me thanks
