Results 1 to 13 of 13
    ishvedoff's Avatar
    Belarus Gomel
    Default Opel Zafira A Y22DTR PSG16 egr off
    Can someone cancel EGR in this file?
    I find DTC table and DTC mask and disable P0400 code in flash. But car same still in limp mode...
    PS: EGR wire still connected, only blocked EGR valve in closed position.
    Thanks.
    Jul 2012
    egr is on file in your
    ishvedoff's Avatar
    Belarus Gomel
    i know that... i only disable p0400 dtc in flash, but car still in limp mode.
    DK Veteran obnchip's Avatar
    Dec 2010
    how you read this ecu?
    a bit off topic, but please someone explain PSG reflash procedure, how to read write flash with tech 2, and how to get these files frrm and to tech2 tool, where are the files placed on cf card for this procedure and what extension
    thank you in advance
    ishvedoff's Avatar
    Belarus Gomel
    UP! Anybody!
    Jul 2012
    Quote Originally Posted by ishvedoff View Post
    if the problem exists it is useless to delete dtc error!
    ishvedoff's Avatar
    Belarus Gomel
    I understand that, so I ask for help or advice on how to properly remove egr in this ecu.
    ishvedoff's Avatar
    Belarus Gomel
    problem solved...
    micromax's Avatar
    South Poland
    how you resolve this problem?
    Nov 2012
    smartville in front of a OBDplug
    you only write it
    optican etc byteshooter surely do this
    my optican support it
    micromax's Avatar
    South Poland
    I am asking for a solution to the problem - " i only disable p0400 dtc in flash, but car still in limp mode."
  13. #13
    Aug 2012
    LATVIA
    a hawe solution for you
    manualy solution
