here attached dump need recalculate checksum ! in Fgtech tell me CKWR2 error ! i think it's cheksum error
and where is the file?
Ecu tuning, DPF, EGR and FLAP remove
ah yes here !! sorry![]()
checksums are correct
so i've a problem, i can't reflash this file to the car, always have CKWR2 error ... any help?
i'm using Fgtech v50
if i guess right thats a MOD file, where is the ori..checksums may be correct but can be missing several blocks
this is what i've readed out via OBD2 before doing anything !
where is the file??
Ohh ok. then you ll have to read in boot mode mate to get a complete file with all checksum blocks!
ok so then we can repair?
here attached file with readed from BootMode !160377.zip
Ok now files looks perfect. waht do you wanan do?
ok so now i've flashed the ECU with a bad DUMP (try volta with EGR remove) and Car don't start, and i can't reflash the original One ... so what do i need to do?
after volta did you correct checksum?
no i didn't , cause volta made the file all 00 00 00 00 ! and i wrote like this !
