Results 1 to 9 of 9
    Jun 2013
    Default DM500s no network connection
    firstly sorry for my bad english, but i'm from France !!
    Since the begin of week I've lost my network connection wiIth no reason !!!
    My settings are :
    Routeur - Freebox
    DHCP enabled
    IP dreambox : 192.168.0.23 (with MAC adress)
    UDP and TCP 80 port open
    Dreambox :
    Network enabled
    DHCP no
    IP : 192.168.0.23
    when I test (yellow button) the 2 first are red, no network !!
    DNS are green OK !!
    Tested with DHCP enabled, same issue
    And what i don't understand is that DCC is working !!! sothis is not anethernet, cable problem
    So if you have any idea !!! PLZ help me
    Sep 2008
    did you try powering off box and modem and router for 30secs then on ,it might connect then,common bug to reset.
    Jun 2013
    i've tested to reset the router, but not the box ! I'll test
    edit : not working
    Sep 2008
    i said power off as in unplug not reset as that does more problems.recheck your network again,what way have you got it connected to lan,faulty cable?
    Jun 2013
    power off was unplug on both demo and router
    I consider my cable is good because FTP is working with DCC and Filezilla !!
    Network checked a lot of time, with many configuration but no improvement !!
    DK Veteran psats's Avatar
    Sep 2008
    some box,s have network problems depending on the software installed
    have you tried rebooting via remote i have a spare box like that.
    Jun 2013
    what do you mean with "rebooting via remote" ?
    Sep 2008
    Quote Originally Posted by geobart View Post
    useing the remote control and chooseing reboot
    DK Veteran NICETOBNICE's Avatar
    Nov 2011
    i have had these issues before reflash box the check again make sure you have dchp enabled then reboot
