    eliasole's Avatar
    Default HYUNDAI SANTA FE 2.0 CRD
    I have this car with ecu number bosch 0281011635 edc15 .
    I try a lot of thinks ,pump ,beck , rail sensor ,ect sensor but car want start until i spray it with starter, Even its cold or hot.
    I read ecu and if anyone can see it and tell me maby there is a problem on it or not.
    Thanks.
    Feb 2012
    hello
    i think you have to clean injectors first
  3. The Following User Says Thank You to king alie For This Useful Post:
    eliasole (10th August, 2013)
    eliasole's Avatar
    Quote Originally Posted by king alie View Post
    hello
    I already did ,check pump , replace Ect , rail sensors , fuel filter with base , vacuum on hoses etc. but car starts only with starter spray and working good.
    DK Veteran agabna's Avatar
    hello
    for start you need good pressure for fuel if you did all i use in some times electrice pump befor the main pump
    some times i got good result
  6. The Following User Says Thank You to agabna For This Useful Post:
    eliasole (13th August, 2013)
    eliasole's Avatar
    Quote Originally Posted by agabna View Post
    hello
    Thanks for the reply , car already have electric pump in tank. Also changed.
  8. #6
    Member serdarmsc's Avatar
    Jul 2012
    Do you check tank interior and pump filter? Fuel tank interior face painted. Some times paint loss and blocking pump line.
